08-05-2004, 13:00
Gene6 FTP Server v3.0.1.45
La version 3.0.1 de G6 FTP Server est disponible. Je rappelle que ce logiciel vous permet d'installer chez vous et de gérer un serveur FTP.
La changements apportés par cette version :
Corrections :
- Admin : when editing a user from a class that has groups defined, clicking OK would incorrectly change the 'groups' property of the user account.
- (0000207) Admin : An exception could occur when deleting servers/domains in the left treeview with the popup menu.
- Admin : menu item 'Actions' was not translated.
- Server : could not use the account tags when user logs on (ie. tags like $USR_CLASS, $USR_ACCOUNT ... in access rights were not replaced).
- Could not delete users and groups using unicode characters not supported by your local charset.
- Admin/Server : fixed several issues with the use of MBCS.
- (0000212) Admin : change 'KBytes' to 'files' when ratio method is set to files so credits are not multiplied by 1024 when displayed on user's side.
- Server : Transfer Limit was applied for download and upload if download limit was enabled.
- Server : Memory leak when using Merge://
- (0000213) Admin : Some times column headers are not shown in ListViews (activity, user list, group list, etc..)
- Admin : Option "use the same schedule every day" in Time of day access may not be checked even if the same schedule is used every day.
- Server : using schedules like '15h00-10h00' in time of day access didn't work.
- Server : Option "Redirect wrong login" didn't check the password of the redirected account.
Ajouts :- Admin : "Import Domain" now also imports banned IP list.
- Admin : added 64KB for Speed Limits in user settings.
- New tags :
- $SRV_STATSCONNECTIONS, $DOM_STATSCONNECTIONS: total number of connections
- $SRV_STATSLOGINS, $DOM_STATSLOGINS, $USR_STATSLOGINS: total number of logins
- $DOM_WHO: list of users connected to the domain
Améliorations/Changements :
- Admin/Server : Manual changes through interface in server/domains/users/groups are now saved immediately instead of waiting 30 seconds (cache).
- $USR_RATIOUP, $USR_RATIODOWN & $USR_RATIOCOUNTMETHOD returns 'None' if ratio is disabled.
- SIZE command now returns 'Not found', instead of 0 for directories.
g6_fs_ftp.dll now uses SIZE command to check if a file exists, then LIST command if SIZE command is not supported by the remote FTP server.
- Admin : simple administrators are no more allowed to view domain properties.
- Admin : Access rights list is sorted so that entries without virtual path are at the end.
Informations :- Languages.sib updated :
- Various extended added.
- TBannedFilesForm.Label3 -> TBannedFilesForm.Label_FileMask
- TDomainLogForm.Label_Security -> TDomainLogForm.Label_LogType
- TBanIPForm.CB_Reason -> TBanIPForm.ComboBox_Reason
- TSettingsAdminForm.Edit_LogFile -> TSettingsAdminForm.ComboBox_LogFile
Télécharger Gene6 FTP Server v3.0.1.45
