delete the second character of a string?
Hi all,
I'm looking for a solution to retrieve ( or copy) the second character of a string. My program is: int iNum=0; char sNum[2]=""; //Somewhere in the program, the integer iNum=92 // Then sprintf (sNum,"%d",iNum); And I want to delete the first character of the string sNum, but i don't know how can i do? Or I want to retrieve the second character of the string sNum which is the value '2' in order to put it to another string, but i don't know how can i do? In sumarize, I want that sNum="2"; or another string ="2"; I don't want to get the whole value iNum. I only want the last value of it. Thanks for your help Bye batteur91 |
Re : delete the second character of a string?
1) You are on a FRENCH forum !!!
2) When you write in english, please try to use correct english grammar and syntax ... |
And what is the language ? C++ ?
I use the C language.
Code:
main()
char sNum[1],res;
/*sNum = "bo"*/
sNum[0]='b';
sNum[1]='o';
/* res is the second character of sNum*/
res=sNum[1];
thanks but, this is not enough,
In my program, sNumis eqaul to "64" for example(a numeric value). sNum is a variable; that means it's gonna change during the execution. So I only can declare the variable sNum at the beginning of my program. I can't declare it as you did below. (sNum[0]='b' and sNum[1]='o'). main() { char sNum[1],res; /*sNum = "bo"*/ sNum[0]='b'; sNum[1]='o'; /* res is the second character of sNum*/ res=sNum[1]; } |
sNum = "what you want when you want where you want"
to get the n-ième char of a string you do : sNum[n-1] for exemple, if sNum is "to" ,you declare a char (here res) and you write res=sNum[1] to get the second character of the string... Or use a int instead of string and do (name_of_int)%10 to get the unit of the integer. |
Bon, batteur, au lieu de t'emmerder à écrire un espèce d'anglais digne d'un gamin de 6ème qui débute, écrit français ... Parce que j'ai vraiment du mal à croire que t'es pas francophone (ton anglais est plein de gallicisme, et ton pseudo fait quand même très français ...) ...
Sinon, pour ton problème, puisque sNum contient un nombre et que dans ton string, tu veux récupérer le nombre sans son premier chiffre, il suffit d'utiliser l'instruction % (modulo) ... Par exemple, si tu as sNum == 64, en faisant sNum = sNum % 10, tu auras alors sNum == 4, soit le dernier chiffre de sNum. |
C'est pas juste vous avez décidé de jouer sans moi, sinon batteur tu peux utiliser les fonctions atoi() de conversion de char* vers int, mais bon ... vu comme le topic est parti ca va etre fun
| P2P : Majors, FAI, Etat, "main dans la main"... | Toitoine | Actualité | 113 | 27-09-2004 19:28 |
| W2K/XP "../ServicesPackFiles" Delete ? | wuub | Personnalisation de Windows | 12 | 16-03-2003 08:31 |
