VirtualDub 1.5.8
VirtualDub 1.5.8
Lien direct de la news : VirtualDub 1.5.8
Une nouvelle version de VirtualDub, célèbre logiciel de manipulation vidéo, vient de sortir.
Voici la liste des changements, en anglais : Current build (1.5.8, stable): [features added] * DirectDraw support is disabled when Terminal Services or Remote Desktop clients are detected to work around a DirectX clipping bug. * Re-enabled places bar on open and save dialogs. * Disabled FPU state warning and made the fixup silent. WAY too many drivers are screwing up the FPU unit. * Edit lists can now be omitted from configuration files without needing to close the source file. [bugs fixed] * Main window is disabled during MPEG-1 scan to prevent crash if main window is closed. * Previous-key and next-key movement commands were not correct for B-frames in an MPEG-1 file. * Fixed decoding of MPEG-1 B-frames at the start of GOPs with broken_link set. * Palette change blocks no longer appear as garbage video streams. In-stream palette changes are still not supported, however. * biSizeImage was incorrect when using fast recompress in YV12 mode. * Sequence appends failing on the first file now throw an error rather than a warning. [regressions fixed] * A race condition in the fast write code occasionally resulted in spurious write errors. * Fixed swapped 00db/00dc tags in AVI output. * Fixed display of 8-bit paletted video. * Program starts under Windows 95 again. Pour télécharger cette nouvelle version, c'est par ici. |
VirtualDub 1.6.0 | LeMoi | Actualité | 1 | 12-02-2005 12:25 |
VirtualDub 1.5.10 (build 18160) | LeMoi | Actualité | 1 | 02-12-2003 12:06 |
VirtualDub 1.5.7 | LeMoi | Vos news | 0 | 21-10-2003 19:55 |
Nouvelle version de VirtualDub | nonoleptitmalin | Logiciels | 4 | 21-05-2003 21:47 |
VirtualDub 1.4.11 | ZK' | Actualité | 1 | 04-11-2002 12:50 |
