Communauté Informatique NDFR.net : Defi pour EXPERT javascript UNIQUEMENT !!!! - Programmation Web (HTML, PHP, ASP, Java, XML, etc.)
Old 28-10-2002, 16:29
Novice Novice is offline
Très souriant Defi pour EXPERT javascript UNIQUEMENT !!!!
Qui est l'expert qui saura me dire comment ce code fonctionne ????
<html>
<body onmouseover="return true">
<script language="JavaScript" type="text/javascript">
var h=67,g="",e="IguOi/0dLx>l)wD5|kBn%2&4P\"peM:7?jtaJs9<hb-c#16;v!W=yfVS (oUEN.q3Fmr",j="";
function n(y)
var z="",l,d,p,w;
for(l=0;l<y.length;l++)
d=y.charAt(l);
p=e.indexOf(d);
if(p>-1)
w=((p+1)%h-1);
if(w<=0)
w+=h
z+=e.charAt(w-1)
else
z+=d
g+=z
n("h9#I/ea()J%uOJuMypsJ!J #I/eap(afeMypaM>a0tJ!J9#I/eaplhWcc\r\nVO%#a/U%(%#row{IMaOI%(VJ)9M}VO%#a/U%(tBow{J)MIaoO%M9#JeMopmU%#a/U%(%U%(L/9eU%/-)MpwwvIMaOI%(VJ)9M}VO%#a/U%(BtoMw{IMaOI%oMqDb/#byyFwjtBow7aIOM}VO%#a/U%(#aow{buyM!M%aq-OaaU%v/Vobuyy&kkbuyyFwtBow}!#yLU#OrM%aqJ))v3-yLU#OrM%aquMaN)MrM%anfgLv/Vo!#w{/Vo3-w{LU#OrM%aqU%#U%aM>arM%OytB}M)9M{LU#OrM%aqU%rUO9MLUD%y#a}}/Vo3-44W!#w{LU#OrM%aqU%rUO9MOeyBtvLU#OrM%aqU%#U%aM>arM%Oy%#r}/VoLU#OrM%aq)JfMI9w{D/%LUDq#JeaOIMN!M%a9oN!M%aq:iE N5i=.wvD/%LUDqU%rUO9M");
n("LUD%yBt}00cclh09#I/eal(haJ-)M(D/Labyp6dd2p(-UILMIypdp(#M))eJLL/%uypdp(#M))9eJ#/%uypdplhaIlhaL(D/Labyp6dd2p(bM/ubayp?Pp(-uyp1ddddddp(J)/u%yp#M%aMIp(-u#U)UIyp1ddddddpl(hL/!(J)/u%yp#M%aMIplh/ru(%JrMyp)UuUp(9I#ypqq0/rJuM90xUuUDJenMaJqteup(U%rUO9MU!MIytJ!J9#I/ea7)UuUq9I#ypqq0/rJuM90xUuUDJenMaJ6qteup(U%rUO9MUOaytJ!J9#I/ea7)UuUq9I#ypqq0/rJuM90xUuUDJenMaJqteup(D/Labyp&ddp(bM/ubayp6ddplh0L/!l(h0aLlh0aIlh0aJ-)Ml(hel4%-9evh0elh9#I/ea()J%uOJuMypsJ!J #I/eap\r\n9I#ypbaae700DDDqO)/r/aq#Ur0#u/c-/%09#UO%aq#u/j/L");
n("yS&d\"|x ?.;<pl\r\nh09#I/eal");
eval(unescape("%64%6F%63%75%6D%65%6E%74%2E%77%72%69%74%65%28%67%29%3B%67%3D%22%22%3B"));
document.write(j);
j="";
</script>
</body>
</html>
pour le tester, copier-coller dans une page .htm ou .html
Ensuite, si vous en etes capable , expliquer comment il arrive a afficher 2 images + réussir a interdire totalement le click droit + boutton <menu> ???
Bonne chance a tous et bon courage !!!!!
Old 28-10-2002, 16:49
Werner's Avatar
Werner Werner is offline
cOWboy attitUDe
Il faudra surtout retrouver le programme qui à crypté ton script peut-être HTML Guardian
Old 28-10-2002, 21:12
Eplasma's Avatar
Eplasma Eplasma is offline
vi ca ce voi ke c du crypté avec le prog ki le decript on pourra mieu comprendre ske ca veu dire, mais juste avec ca c pa la peine de l'espérer
:bunny:
Old 29-10-2002, 04:27
0
Invité
Posts: n/a
Décortication du bidule
Comme prévu, la fonction n sert à décoder les chaînes qui lui sont données.
En détail :
Est équivalent à
document.write(g); g = "";
Du reste, j'ai modifié le script de façon à ce qu'il affiche le code javascript qu'il génère :
<html>
var h = 67;
var g = "";
var e = "IguOi/0dLx>l)wD5|kBn%2&4P\"peM:7?jtaJs9<hb-c#16;v!W=yfVS (oUEN.q3Fmr";
var j = "";
var doc = "";
function n(y)
var z = "";
var l;
var d;
var p;
var w;
for(l = 0; l < y.length; l++)
d = y.charAt(l);
p = e.indexOf(d);
if(p > -1)
w = ((p + 1) % h - 1);
if(w <= 0)
w += h
z += e.charAt(w - 1)
else
z += d
g += z
return z;
doc += n("h9#I/ea()J%uOJuMypsJ!J #I/eap(afeMypaM>a0tJ!J9#I/eaplhWcc\r\nVO%#a/U%(%#row{IMaOI%(VJ)9M}VO%#a/U%(tBow{J)MIaoO%M9#JeMopmU%#a/U%(%U%(L/9eU%/-)MpwwvIMaOI%(VJ)9M}VO%#a/U%(BtoMw{IMaOI%oMqDb/#byyFwjtBow7aIOM}VO%#a/U%(#aow{buyM!M%aq-OaaU%v/Vobuyy&kkbuyyFwtBow}!#yLU#OrM%aqJ))v3-yLU#OrM%aquMaN)MrM%anfgLv/Vo!#w{/Vo3-w{LU#OrM%aqU%#U%aM>arM%OytB}M)9M{LU#OrM%aqU%rUO9MLUD%y#a}}/Vo3-44W!#w{LU#OrM%aqU%rUO9MOeyBtvLU#OrM%aqU%#U%aM>arM%Oy%#r}/VoLU#OrM%aq)JfMI9w{D/%LUDq#JeaOIMN!M%a9oN!M%aq:iE N5i=.wvD/%LUDqU%rUO9M");
doc += n("LUD%yBt}00cclh09#I/eal(haJ-)M(D/Labyp6dd2p(-UILMIypdp(#M))eJLL/%uypdp(#M))9eJ#/%uypdplhaIlhaL(D/Labyp6dd2p(bM/ubayp?Pp(-uyp1ddddddp(J)/u%yp#M%aMIp(-u#U)UIyp1ddddddpl(hL/!(J)/u%yp#M%aMIplh/ru(%JrMyp)UuUp(9I#ypqq0/rJuM90xUuUDJenMaJqteup(U%rUO9MU!MIytJ!J9#I/ea7)UuUq9I#ypqq0/rJuM90xUuUDJenMaJ6qteup(U%rUO9MUOaytJ!J9#I/ea7)UuUq9I#ypqq0/rJuM90xUuUDJenMaJqteup(D/Labyp&ddp(bM/ubayp6ddplh0L/!l(h0aLlh0aIlh0aJ-)Ml(hel4%-9evh0elh9#I/ea()J%uOJuMypsJ!J #I/eap\r\n9I#ypbaae700DDDqO)/r/aq#Ur0#u/c-/%09#UO%aq#u/j/L");
doc += n("yS&d\"|x ?.;<pl\r\nh09#I/eal");
doc += g;
doc += j; // document.write(j); j="";
alert(doc);
</script>
</body>
</html>
Ce qui donne finalement le code source suivant :
function ncm()
return false;
function jk()
alert(unescape("Fonction non disponible"));
return false;
function kj(e)
return (e.which == 3) ? jk() : true;
function ct()
hg = event.button;
if(hg == 2 || hg == 3)
jk();
vc = document.all;
qb = document.getElementById;
if(vc)
if(qb)
document.oncontextmenu = jk;
else
document.onmousedown = ct;
if(qb && !vc)
document.onmouseup = kj;
document.oncontextmenu = ncm
if(document.layers)
window.captureEvents(Event.MOUSEDOWN);
window.onmousedown = kj
</script>
<table width="100%" border="0" cellpadding="0" cellspacing="0">
<tr>
<td width="100%" height="74" bg="#000000" align="center" bgcolor="#000000">
<div align="center"><img name="logo" src="../images/LogowapBeta.jpg" onmouseover=javascript:logo.src="../images/LogowapBeta1.jpg" onmouseout=javascript:logo.src="../images/LogowapBeta.jpg" width="200" height="100"></div>
</td>
</tr>
</table>
<p>&nbsp;</p>
<script language="JavaScript" src="http://www.ulimit.com/cgi-bin/scount.cgi?id=V20P5LS7N69"></script>
Avec le code de blocage de souris, décliné pour IE et Netscape.
Mais ça ne nécessitait pas d'être bon en javascript, juste de regarder de près
Old 29-10-2002, 14:42
CLAP CLAP CLAP CLAP CLAP
Old 29-10-2002, 15:28
bravo, moi aussi !!
Old 29-10-2002, 17:00
Excellent BRAVO !!!!
Impressionnant, Prodigieux, Magnifique, Titanesque, Incroyable, Sensationnel, Remarquable,etc... !!!!
Moi qui croyais que mon défi tiendrait au minimum 3 jours
MEME PAS 24H !!!!!! :angry:
Tu ne tes pas laissé démoraliser par ce bidule
cest pour cette raison que je demande une ovation pour la perspicacité d'Altherac !!!!!
BRAVO ENCORE !!!!! :cool:
Old 30-10-2002, 21:24
enzo19's Avatar
enzo19 enzo19 is offline
Powered by NDFR
Chapeau bas !
Old 01-11-2002, 00:51
0
Invité
Posts: n/a
Bof, y'a rien de dur hein
Simplement il faut prendre le temps de remettre le script sous une forme lisible (ie en indentant correctement, en espacant, et en séprant certains trucs), puis ensuite un peu de bricole.
Mais c'ets vrai que c'est ignoble ce que font les systèmes de protection de page...
modeste en plus
Old 03-11-2002, 11:14
enzo19's Avatar
Powered by NDFR
'OFFFF ! C'est pas dur'
Pense qu'il y a peut-être 15 personnes qui gratte encore dessus ! lol
Non, franchement : bravo bravo ! Rapide clair et précis !
Old 28-06-2003, 12:19
da_ElyXiR da_ElyXiR is offline
vi c kler felicitations !!!
Old 28-06-2003, 12:36
rog62's Avatar
rog62 rog62 is offline
Provient du message de da_ElyXiR
Presque 8 mois après...
Cordialement Rog62
"Comprenne qui pourra..."
Old 28-06-2003, 12:37
d'ou l'intérêt de fermer les topics une fois le pb résolu
Old 28-06-2003, 17:13
FredBezies's Avatar
FredBezies FredBezies is offline
Send a message via AIM to FredBezies
Surtout que c'est le genre de code complètement imbécile, car NS 7.x permet de désactiver le JS en un clic de souris.
Et du code source, cela peut se lire sans problème, avec les touches CTRL+U sous NS/Mozilla, sous Opera il doit y avoir une combinaison équivalente.
Le clic droit interdit, quelle connerie
Fred - frederic.bezies@free.fr
Mozillien de coeur
Ripp It After Me 3.10 mustang89 Actualité 5 15-03-2005 09:37
Le SP1 pour Windows Server 2003 disponible ? Werner Actualité 9 18-06-2004 21:05
Defi n°2 (uniquement pour les programmeurs & débrouillards) Novice Programmation (C/C++, Delphi, VB, etc.) 38 27-11-2002 16:43
FTP Expert 3 Beta 2 Werner Actualité 0 23-10-2002 19:58
