Comme principales nouveautés de cette version 4.5, le support officiel de Mac OS X Leopard, mais aussi le support de l'HTML (basé sur le moteur WebKit) et du Flash au sein des widgets. Coté sécurité, Yahoo! nous promet que l'accès de HTML sera très restreint et que seul le code local pourra accéder à toute les fonctionnalités de YWE 4.5.
Pour ce qui est du changelog, il est long, très long même
Fixes
Konfabulator 4.5 also addresses a number of known issues from previous releases
* Implemented text speedup for Mac.
* Fixed event.key
* Added support for numlock modifier on keyboard, mouse, and drag events
* map the window levels correctly (mac only)
* Added timeout property to XHR.
* Added JSON object (from json.org).
* Leopard support
* Fix issue with unlocalized \"Preferences\" submenu in system tray.
* Allow CSS to affect text alignment even in non-wrapped text objects. Only works with a minimum version of 4.5 or later.
* Fix issue where saveImageToFile() couldn't deal with scrolled frames.
* Fix localization of preferences dialog title.
* Fix localization of dialog title when iTunes is not installed.
* FINALLY support ctrl-a and ctrl-e in the evaluation field in the debug window on Windows.
* Always set system.event when minVersion >= 4.5. system.event is, however, considered deprecated. You should always use the event passed to your handlers.
* Implement URL properties to expose a URL 'cracking' API, i.e. you can access the components of a URL.
* Get Drag/Drop working for window objects (Windows only?)
* Allow 0 as a valid length value in CSS. It's supposed to be valid.
* Only print warnings about elements being in widget and metadata files if the values actually differ
* Changed XPath to work to spec. It wasn't returning the correct result for string() functions.
* Added window.getCurrentMousePosition()
* Added window.close()
* Added widget.createWindowFromXML()
Changelog complet de Yahoo! Widget Engine 4.5
Tous ces changements ont une certaines influence sur les anciens widgets : ils ne sont plus compatibles ou ne possèdent pas les critères de sécurités requis pour être exécutés.Fixes
* Fixed event.key
* Leopard support
Télécharger Yahoo! Widget Engine 4.5 pour Windows 2000 SP4/ XP SP2/Vista et MacOS X 10.3.9+
iconse qui ont changes !!!!!
