Par LeMoi, le 07-06-2004 à 11:32
On nous annonce que cette version du fameux codec open-source qu'est XviD ne serait qu'un "bugfix", donc pas de grands changements mais seulement des corrections de petits bugs :
- xvidcore
- DC misprediction caused by missing value clipping (this one for real).
- Fixed bugs triggered by 1fps sequences in decoder.
- Fixed bug in trellis that was causing block skipping in later stages.
- Fixed some ME buglet that could cause suboptimal results for bframes.
- VFW frontend
- Fixed error in bitrate calc when given bitrate and size (2.4%).
- Added ICM compatibility for Office Suites (OpenOffice.org, MS Office...).
- Added more known audio filetypes.
- Debian dir
- removed from the release tarball in an effort to get the package
into SID as a non native package.
Télécharger XviD 1.0.1
Et en même temps apparait donc la version corrigée de Koepi :
- Core :
- small trellis bug which probably reduced sharpness of the image, but possibly even produced artifacts
- motion estimation buglet slightly reduced b-frame's quality
- 1 fps files failed to decode
- intra coefficients were sometimes not clipped correctly, which might (in theory) produce artifacts (don't worry, noone has seen the artifacts yet)
- if two p-frames were more than one second apart, b-frames in between are not decoded
- Vfw :
- video was not playable via ICM (mplay32.exe, files embedded in Office applications etc)
- calculator did not open many useful audio/subs extensions by default
- calculator calculated audio size wrong when given bitrate and length (2.4% error
Télécharger Koepi's XviD 1.0.1 (06/05/2004)
notons qu'au passage, le site de Koepi est désormais accessible sur www.koepi.org
