Winamp 5.54 - Actualités informatiques - NDFR.net
Winamp de Nullsoft est un lecteur rapide, flexible et de haute fidélité pour Windows. Comme personne ne le connaît, nous vous rappelons que Winamp supporte beaucoup de codecs audio (MP3 et OGG, AAC, WAV, modèle, XM, S3M, LUI, le MIDI, etc.) et video (AVI, ASF, MPEG, NSV, etc.) et est entièrement skinnable. Une interface radio et TV sur internet est aussi disponible.
Changements apporté à Winamp 5.54:
* New: Chinese, Japanese & Korean installer translations and language packs
* New: [in_swf] Adobe Shockwave Flash (SWF, RTMP) playback support
* New: [gen_dropbox] Winamp DropBox alpha (use: Ctrl-Shift-D)
* New: [Online Services] AOL Radio featuring CBS Radio (requires in_flv)
* Improved: Background reading option for playlist metadata
* Improved: Classic songticker scrolling for Winamp Modern skin pledit winshade
* Improved: Vista elevation (fixes: installing skins, filetype reg, Pro reg)
* Improved: Zero padding option for playlist item numbers
* Improved: [in_flv] Better streaming support and other improvements
* Improved: [in_mp3] Added APEv2 tag options to configuration
* Improved: [in_mp3] Optional retention of existing APEv2 headers
* Improved: [ml_disc] Artwork support for Data CD Reader
* Improved: [ml_disc] Better detection of any copy operations in progress
* Improved: [ml_disc] Improved start times if ml_disc view is active
* Improved: [ml_local] Redesigned 'Show Info' panel
* Improved: [ml_nowplaying] Redesigned 'Now Playing' artist experience
* Improved: [ml_playlists] Right-click option to sort list of playlists alphabetically
* Improved: [pmp_usb] Connect/Disconnect/Blacklist config options
* Fixed: Alt+F4 closing Winamp instead of individual dialogs
* Fixed: Bento browser redirecting network drive url's to Winamp Search
* Fixed: Blank playlist when in docked toolbar mode and Winamp is minimized
* Fixed: Modern skin component windows appearing individually in Alt+Tab
* Fixed: Multi-flashing on startup when previously closed whilst minimized to systray
* Fixed: Pure Virtual Function Call runtime crash errors
* Fixed: Redraw issue when built-in classic vis is disabled
* Fixed: Various multi-monitor docking issues
* Fixed: Various other 5.53-specific keyboard accelerator issues
* Fixed: [Bento] Drag+Drop into Playlist from Open Files dialog
* Fixed: [burnlib] 'CD Drive locked by another Winamp process' on 2nd burn attempt
* Fixed: [burnlib] 'Burner releasing failed' error
* Fixed: [dsp_sps] Crash on close when config Help dialog is still open
* Fixed: [enc_flac] MD5 checksum generation
* Fixed: [gen_ff] Attached vis plugin crash on winshade to normal mode in Modern skin
* Fixed: [gen_hotkeys] Assigning Winkey with already used Ctrl combinations
* Fixed: [gen_ml] Enter/Shift+Enter broken for ML treeview items (5.53-specific)
* Fixed: [in_cdda] Composer/Conductor logic bug when saving CDDB data to database
* Fixed: [in_flac] Minor metadata writing bugs
* Fixed: [in_midi] Seeking with 'DM/MS Synth' device in Streamed playback mode
* Fixed: [in_mp3] Crash on files with invalid/corrupt gapless data
* Fixed: [in_mp3] Create new ID3v1/v2 tags configuration setting
* Fixed: [in_vorbis] Huge lag on files with large embedded cover art
* Fixed: [in_vorbis] Metadata & Format Info display for streams in View File Info
* Fixed: [in_vorbis] Potential unicode-related crash on open/close issue
* Fixed: [jpeg.w5s] Saving corrupt album art
* Fixed: [ml_autotag] Results dialog hidden under Winamp when AOT is enabled
* Fixed: [ml_disc] Small resource leak
* Fixed: [ml_playlists] Enter/Shift+Enter broken for selected ML Playlist items
* Fixed: [ml_playlists / ml_transcode] Sending playlists from ML tree to Transcoder
* Fixed: [ml_wire] 404/timeout with valid rss feeds on Vista
* Misc: Miscellaneous localization tweaks, fixes & updates
* Misc: More miscellaneous general tweaks, improvements, fixes and optimizations
* Misc: Setup fixes (Agent not always starting, WLZ filetype not registering, etc)
* Misc: Various other 'Winamp Modern' & 'Bento' skin updates
* Misc: [enc_flac] Now encodes using libFLAC instead of Flake
* Updated: Bento skin v1.2
* Updated: freetype 2.3.7
* Updated: libpng 1.2.28
* Updated: [enc_lame] LAME 3.98
Télécharger Winamp 5.54 Full Français
Télécharger Winamp 5.54 Lite Français
Télécharger Winamp 5.54 Full multilingue
1 commentaire pour “Winamp 5.54”
  1. 1for-matik a dit (le 9 juillet 2008 à 23h26)
    huhu, j'arrive 40mn trop tard
Afficher l'actualité “Winamp 5.54” sur le forum
