Pour le changelog, c'est par là :
Winamp 5.53.1
* Fixed: Bento browser redirecting some url's to Winamp Search
* Fixed: Bento collapse/expand button bug
* Fixed: Recent URL's not saving (5.53-specific)
* Fixed: Total time display of selected tracks in Classic playlist (5.53-specific)
* Fixed: [jnetlib] AOL Radio skipping/buffer issue
* Fixed: [ml_local] Right-click Play/Enqueue all items issue in 3-pane views
* Fixed: [ml_playlists] Broken right-click context menu items (5.53-specific)
Winamp 5.53
* Improved: Different shell descriptions for different associated filetypes
* Improved: New 'Refine Search' feature in Cover Art Downloader dialog
* Improved: Unicode support for Language Packs incompatible with system locale
* Improved: [in_cdda] Now reads & writes CD data to an NDE database
* Improved: [in_cdda/ml_disc] Reimplementation of simple offline CD Info Editor
* Improved: [in_flac] Faster FLAC metadata gathering
* Improved: [in_mp3] More accurate .AAC length calculation
* Improved: [in_wav/in_mp4] Support for http streaming of files larger than 2GB
* Improved: [ml_disc] Added support for Data CD reading (w.i.p.)
* Improved: [ml_local/nde] Background scanning & database optimizations
* Improved: [ml_local] Unicode compliant filename-based metadata guessing
* Improved: [ml_transcode] Remove trailing periods from destination filepath
* Improved: [pmp_usb] Added AlbumArtist support to Naming Convention
* Fixed: Classic EQ appearing with Modern skins after switch->minimize->restore
* Fixed: Various miscellaneous Album Art related issues
* Fixed: [enc_lame] Now rejects multi-channel and above 48KHz source files
* Fixed: [gen_ff] Translated skin image loading
* Fixed: [gen_ml] Header sort arrow and Rating column display under Windows 2000
* Fixed: [gen_ml] Various drawing glitches when changing views
* Fixed: [in_cdda] CDDB crash under limited connectivity conditions
* Fixed: [in_cdda] Spectrum vis in analog MCI playback mode
* Fixed: [in_flac] Small memory leak when writing FLAC metadata
* Fixed: [in_flv] Last two seconds of flv videos being cut off
* Fixed: [in_mp3] Crash on encountering a bad ID3v2 version (e.g. ID3v2.F)
* Fixed: [in_mp4] Crash on file-not-found during background decode
* Fixed: [in_wave] Infinite loop on attempted repeat playback of dead files
* Fixed: [in_wm] ASX v2 loading
* Fixed: [in_wm] Crash on files & streams with a huge discontinuity jump
* Fixed: [in_wm / out_ds] Copy 'Status' to clipboard Unicode bug
* Fixed: [ml_autotag] Crash with certain tracks
* Fixed: [ml_history] Crash on drag+drop all history items to playlist
* Fixed: [ml_local] Rating of items with Unicode filenames
* Fixed: [ml_online/orb] Nodes dropping to bottom of ML tree on Lang Pack change
* Fixed: [ml_playlists] Play playlist from Media Library main menu item
* Fixed: [pmp_ipod] Filename length incompatibility with iPod Music Quiz v2
* Fixed: [pmp_ipod] Missing 'Advanced' button in Edit Query dialog
* Fixed: [pmp_ipod] Physical deletion of playing file
* Misc: Added Russian installer translation and language pack
* Misc: In2TV removed from Online Services
* Misc: Installer now built with NSIS Unicode version [thanks Jim Park]
* Misc: More miscellaneous general tweaks, improvements and optimizations
* Misc: Moved shared zlib.dll compression library out of winamp.exe
* Updated: Bento skin v1.1 #120
Winamp 5.53.1
Winamp 5.53
Télécharger Winamp 5.53.1 Full Français (9.1 Mo)
Télécharger Winamp 5.53.1 Lite Français (3.3Mo)
Télécharger Winamp 5.53.1 Full Multilangues (12.7Mo)
carte mère et le processeur
