Winamp 5.53.1 (màj) - Actualités informatiques - NDFR.net
Nouvelle version pour lecteur multimédia mondialement connu développé par l'équipe d'AOL qui nous arrive en version 5.53 contenant principalement des corrections de bugs et autres améliorations de composants notamment un meilleur support de l'Unicode pour les packs de langues.
Pour le changelog, c'est par là :
Winamp 5.53.1
* Fixed: Bento browser redirecting some url's to Winamp Search
* Fixed: Bento collapse/expand button bug
* Fixed: Recent URL's not saving (5.53-specific)
* Fixed: Total time display of selected tracks in Classic playlist (5.53-specific)
* Fixed: [jnetlib] AOL Radio skipping/buffer issue
* Fixed: [ml_local] Right-click Play/Enqueue all items issue in 3-pane views
* Fixed: [ml_playlists] Broken right-click context menu items (5.53-specific)
Winamp 5.53
* Improved: Different shell descriptions for different associated filetypes
* Improved: New 'Refine Search' feature in Cover Art Downloader dialog
* Improved: Unicode support for Language Packs incompatible with system locale
* Improved: [in_cdda] Now reads & writes CD data to an NDE database
* Improved: [in_cdda/ml_disc] Reimplementation of simple offline CD Info Editor
* Improved: [in_flac] Faster FLAC metadata gathering
* Improved: [in_mp3] More accurate .AAC length calculation
* Improved: [in_wav/in_mp4] Support for http streaming of files larger than 2GB
* Improved: [ml_disc] Added support for Data CD reading (w.i.p.)
* Improved: [ml_local/nde] Background scanning & database optimizations
* Improved: [ml_local] Unicode compliant filename-based metadata guessing
* Improved: [ml_transcode] Remove trailing periods from destination filepath
* Improved: [pmp_usb] Added AlbumArtist support to Naming Convention
* Fixed: Classic EQ appearing with Modern skins after switch->minimize->restore
* Fixed: Various miscellaneous Album Art related issues
* Fixed: [enc_lame] Now rejects multi-channel and above 48KHz source files
* Fixed: [gen_ff] Translated skin image loading
* Fixed: [gen_ml] Header sort arrow and Rating column display under Windows 2000
* Fixed: [gen_ml] Various drawing glitches when changing views
* Fixed: [in_cdda] CDDB crash under limited connectivity conditions
* Fixed: [in_cdda] Spectrum vis in analog MCI playback mode
* Fixed: [in_flac] Small memory leak when writing FLAC metadata
* Fixed: [in_flv] Last two seconds of flv videos being cut off
* Fixed: [in_mp3] Crash on encountering a bad ID3v2 version (e.g. ID3v2.F)
* Fixed: [in_mp4] Crash on file-not-found during background decode
* Fixed: [in_wave] Infinite loop on attempted repeat playback of dead files
* Fixed: [in_wm] ASX v2 loading
* Fixed: [in_wm] Crash on files & streams with a huge discontinuity jump
* Fixed: [in_wm / out_ds] Copy 'Status' to clipboard Unicode bug
* Fixed: [ml_autotag] Crash with certain tracks
* Fixed: [ml_history] Crash on drag+drop all history items to playlist
* Fixed: [ml_local] Rating of items with Unicode filenames
* Fixed: [ml_online/orb] Nodes dropping to bottom of ML tree on Lang Pack change
* Fixed: [ml_playlists] Play playlist from Media Library main menu item
* Fixed: [pmp_ipod] Filename length incompatibility with iPod Music Quiz v2
* Fixed: [pmp_ipod] Missing 'Advanced' button in Edit Query dialog
* Fixed: [pmp_ipod] Physical deletion of playing file
* Misc: Added Russian installer translation and language pack
* Misc: In2TV removed from Online Services
* Misc: Installer now built with NSIS Unicode version [thanks Jim Park]
* Misc: More miscellaneous general tweaks, improvements and optimizations
* Misc: Moved shared zlib.dll compression library out of winamp.exe
* Updated: Bento skin v1.1 #120
Télécharger Winamp 5.53.1 Full Français (9.1 Mo)
Télécharger Winamp 5.53.1 Lite Français (3.3Mo)
Télécharger Winamp 5.53.1 Full Multilangues (12.7Mo)
Afficher l'actualité “Winamp 5.53.1 (màj)” sur le forum
