Sommaire des nouveautés, on pourra signaler que Winamp s'ajoute dans les options de lecture automatique lors de l'insertion d'un CD ou une clé USB, qu'il utilise enfin le module d'association des programmes sur Vista, qu'il possède une nouvelle version de son equalizer certifiée ISO, un décodeur FLV (uniquement VP6 et non H.263) et ajoute une petite colonne "BPM"
Le reste des nouveautés dans ce petit changelog pas trop long :
Changes in Winamp 5.51 :
- New: Autoplay Handlers for Audio, MP3 and Video CD's on WinXP & Vista
- New: Default Programs registration for installations on Windows Vista
- New: Optional Constant-Q Equalizer and optional ISO Standard frequency bands
- New: [in_flv] Flash Video decoder (vp6 only, not h.263)
- New: [ml_local] BPM column
- Improved: Browser download manager now uses CD Ripping destination folder
- Improved: Deletion of embedded album art via Artwork tab in File Info
- Improved: More accurately translated Language Packs (see note below)
- Improved: More miscellaneous UI/dialog tweaks & improvements
- Improved: Option to set the number of pixels to scroll for modern songticker
- Improved: [Gracenote/MusicID] Better error checking & memory cache optimizations
- Improved: [gen_ff] More miscellaneous freeform skinning engine optimizations
- Improved: [gen_hotkeys] Added optional WM_APPCOMMAND support for media keys
- Improved: [gen_hotkeys] Added increase + decrease rating on current track
- Improved: [in_dshow] Reading of length and bitrate for non-default video formats
- Improved: [in_flac] Optimized disk caching for increased performance
- Improved: [in_mp3] Better optimization for older Pentium Pro/2/3 cpu's
- Improved: [in_mp3] Support for reading ALBUM ARTIST field if TPE2 not present
- Improved: [in_mp4] Better Unicode support and metadata read optimizations
- Improved: [in_mp4] Optimized disk caching/reading
- Improved: [in_vorbis] Support for reading YEAR field if DATE not present
- Improved: [ml_disc/in_cdda] Disc reading tweaks and other general optimizations
- Improved: [ml_history] New tracking control options
- Improved: [ml_local] Album column sorting order logic
- Improved: [ml_local] Better playlist handling
- Improved: [ml_local] Bumped track# metadata guessing limit from 130 to 999
- Improved: [ml_local] Database query and memory optimizations
- Improved: [ml_pmp] Support for drag&drop from Explorer into portable device view
- Improved: [ml_transcode] Prompt to delete aborted transcodes
- Fixed: Artwork not found if .nfo filename contains a period
- Fixed: ASX Parser converting all stream links in .asx playlists to upper case
- Fixed: Classic songticker wraparound glitchiness
- Fixed: Global Hotkeys list destroyed when changing language packs
- Fixed: Gracenote/MusicID not using Winamp's proxy setting
- Fixed: Parsing of ansi ASX playlists containing non-standard characters
- Fixed: Restore from System Tray if previously closed in a minimized state
- Fixed: Setup resetting desktop icons
- Fixed: Spectrum vis incompatibility crash with some 3rd-party input plugins
- Fixed: Truetype replacement font alignment in Winamp Modern winshade songticker
- Fixed: Various miscellaneous keyboard shortcut issues
- Fixed: Winamp Agent registry entry typo (wianmpa.exe)
- Fixed: [Bento] Collapse/Expand Playlist not respecting 'Show Album Art' setting
- Fixed: [gen_ff] Potential high CPU usage of songticker object
- Fixed: [gen_hotkeys] Restore from minimized state whilst About dialog is open
- Fixed: [gen_ml] Blank ML when restarting Winamp from a minimized state
- Fixed: [gen_ml] Cancelling Online Media password prompt clears password & filters
- Fixed: [in_dshow] Miscalculation of some mpeg video lengths
- Fixed: [in_flac] Divide-by-zero crash on corrupt files
- Fixed: [in_mp3] Deleting Lyrics3 tag in Alt+3 Editor also deletes ID3v1 tag
- Fixed: [in_mp3] Handling of ID3v2 with bad version/revision #'s
- Fixed: [in_mp3] ID3v2 parsing crash with some mp3's
- Fixed: [in_mp3] ID3v2 tag not showing when ID3v1 tag reading is disabled in config
- Fixed: [in_mp3] MPEG Info not showing in Alt+3 for files with large ID3v2 tags
- Fixed: [in_mp3] Now only reads first ID3v2 tag if more than one is present
- Fixed: [in_mp3] Winamp UI freezes when loading certain corrupt mp3's
- Fixed: [in_mp4] Playback of mp3 in mp4 container
- Fixed: [in_mp4] Seeking when paused
- Fixed: [in_mp4/jpeg.w5s] Crash when Art field is in metadata with no embedded art
- Fixed: [in_vorbis] UTF8->UTF16 optimized (fixes File Info delay bug)
- Fixed: [libmp4v2] Corrupt m4a's not playing, better handling of ones beyond repair
- Fixed: [ml_autotag] Stops processing when switching to another ml view
- Fixed: [ml_disc] CD view/titles not refreshing when ejecting old/inserting new CD
- Fixed: [ml_disc] Crash when using invalid strings in playlist filename generation
- Fixed: [ml_disc] No Burn button under some system configurations
- Fixed: [ml_disc/ml_pmp/ml_transcode] Processing of # in Destination Folder path
- Fixed: [ml_local] Artist column in descending order when sorting by Year
- Fixed: [ml_local] Down key in Search field not focusing the Simple View list
- Fixed: [ml_local] Last Updated, Album Gain & Podcast column sorting orders
- Fixed: [ml_playlists] Shift+Enter hotkey to Enqueue playlist
- Fixed: [ml_plg] Crash when stopping Playlist Generator scan or resetting database
- Fixed: [ml_pmp] Column sorting orders
- Fixed: [ml_rg] Restore from minimized state whilst rg results dialog is open
- Fixed: [ml_transcode] Restore from minimized state whilst config dialog is open
- Fixed: [ml_wire] Podcasts not being downloaded if
- Fixed: [ml_wire] Lockup when encountering scripts in field
- Fixed: [out_disk] Output folder always resetting to My Documents\My Music
- Fixed: [pmp_ipod] 'Add album art' option always checkmarked
- Fixed: [tataki] Potential crash when encountering an invalid/superficial error
- Techspot : a bunch of copy and paste idiots
- Misc: Alt+3 Auto-Tag now saves Gracenote FileId and ExtData fields
- Misc: Double-click Stereo indicator to open Playback prefs (Bento & Modern skins)
- Misc: Installation is now prevented on Win9x
- Misc: Split the Playback prefs into 3 tabs: Playback, Equalizer & Replay Gain
- Misc: Various installer setup & localization translation tweaks
- Misc: Various Bento skin fixes, tweaks and improvements
- Misc: Various Winamp Modern skin 5.5-related updates
- Misc: [ml_local] Removed deprecated 'Show album gain values' option in Prefs
- Updated: Bento skin #116
- Updated: libpng 1.2.22
- Updated: [vis_milk2] MilkDrop 2.0b
Télécharger Winamp 5.51 Full Français (8.7 Mo)
Télécharger Winamp 5.51 Lite Français (3.1 Mo, oui ça n'a plus vraiment l'air d'un vrai "light" )
SanDisk lance la carte SDHC la plus rapide...
Test du NAS Netgear ReadyNAS Duo RND2150
Quel est votre lecteur MP3 principal ?
4 commentaires pour “Winamp 5.51”
Cette version ne propose que des corrections de bogues, notamment au niveau du support de l'unicode des noms de fichiers et du skin Bento.
* Improved: Better Unicode filename support for enc_*.dll audio encoders
* Improved: [ml_transcode] Unicode filename support
* Improved: [in_mp3] APEv2 tag support
* Improved: [in_flac] Support for reading/writing BPM metadata
* Improved: [nde] Optimized for faster mldb query results
* Improved: [vis_milk2] Pixel shaders now work on onboard Intel graphics chips
* Fixed: Comment field character limitation in Basic Info tab of File Editor
* Fixed: Playback Thread Priority middle setting resets to Lowest
* Fixed: [in_mp3] Ultravox streaming metadata stack overflow (Thanks: Secunia)
* Fixed: [in_mp4] Crash when attempting to play non-existent files
* Fixed: [in_vorbis] Crash when clearing existing metadata fields in File Info
* Fixed: [in_wave] Transcoding of floating point WAV files
* Fixed: [ml_transcode] Memory leaks
* Misc: More miscellaneous general tweaks and improvements
* Updated: Bento skin #118
Pour le changelog, c'est par là :
Winamp 5.53.1
* Fixed: Bento browser redirecting some url's to Winamp Search
* Fixed: Bento collapse/expand button bug
* Fixed: Recent URL's not saving (5.53-specific)
* Fixed: Total time display of selected tracks in Classic playlist (5.53-specific)
* Fixed: [jnetlib] AOL Radio skipping/buffer issue
* Fixed: [ml_local] Right-click Play/Enqueue all items issue in 3-pane views
* Fixed: [ml_playlists] Broken right-click context menu items (5.53-specific)
Winamp 5.53
* Improved: Different shell descriptions for different associated filetypes
* Improved: New 'Refine Search' feature in Cover Art Downloader dialog
* Improved: Unicode support for Language Packs incompatible with system locale
* Improved: [in_cdda] Now reads & writes CD data to an NDE database
* Improved: [in_cdda/ml_disc] Reimplementation of simple offline CD Info Editor
* Improved: [in_flac] Faster FLAC metadata gathering
* Improved: [in_mp3] More accurate .AAC length calculation
* Improved: [in_wav/in_mp4] Support for http streaming of files larger than 2GB
* Improved: [ml_disc] Added support for Data CD reading (w.i.p.)
* Improved: [ml_local/nde] Background scanning & database optimizations
* Improved: [ml_local] Unicode compliant filename-based metadata guessing
* Improved: [ml_transcode] Remove trailing periods from destination filepath
* Improved: [pmp_usb] Added AlbumArtist support to Naming Convention
* Fixed: Classic EQ appearing with Modern skins after switch->minimize->restore
* Fixed: Various miscellaneous Album Art related issues
* Fixed: [enc_lame] Now rejects multi-channel and above 48KHz source files
* Fixed: [gen_ff] Translated skin image loading
* Fixed: [gen_ml] Header sort arrow and Rating column display under Windows 2000
* Fixed: [gen_ml] Various drawing glitches when changing views
* Fixed: [in_cdda] CDDB crash under limited connectivity conditions
* Fixed: [in_cdda] Spectrum vis in analog MCI playback mode
* Fixed: [in_flac] Small memory leak when writing FLAC metadata
* Fixed: [in_flv] Last two seconds of flv videos being cut off
* Fixed: [in_mp3] Crash on encountering a bad ID3v2 version (e.g. ID3v2.F)
* Fixed: [in_mp4] Crash on file-not-found during background decode
* Fixed: [in_wave] Infinite loop on attempted repeat playback of dead files
* Fixed: [in_wm] ASX v2 loading
* Fixed: [in_wm] Crash on files & streams with a huge discontinuity jump
* Fixed: [in_wm / out_ds] Copy 'Status' to clipboard Unicode bug
* Fixed: [ml_autotag] Crash with certain tracks
* Fixed: [ml_history] Crash on drag+drop all history items to playlist
* Fixed: [ml_local] Rating of items with Unicode filenames
* Fixed: [ml_online/orb] Nodes dropping to bottom of ML tree on Lang Pack change
* Fixed: [ml_playlists] Play playlist from Media Library main menu item
* Fixed: [pmp_ipod] Filename length incompatibility with iPod Music Quiz v2
* Fixed: [pmp_ipod] Missing 'Advanced' button in Edit Query dialog
* Fixed: [pmp_ipod] Physical deletion of playing file
* Misc: Added Russian installer translation and language pack
* Misc: In2TV removed from Online Services
* Misc: Installer now built with NSIS Unicode version [thanks Jim Park]
* Misc: More miscellaneous general tweaks, improvements and optimizations
* Misc: Moved shared zlib.dll compression library out of winamp.exe
* Updated: Bento skin v1.1 #120
* New: Chinese, Japanese & Korean installer translations and language packs
* New: [in_swf] Adobe Shockwave Flash (SWF, RTMP) playback support
* New: [gen_dropbox] Winamp DropBox alpha (use: Ctrl-Shift-D)
* New: [Online Services] AOL Radio featuring CBS Radio (requires in_flv)
* Improved: Background reading option for playlist metadata
* Improved: Classic songticker scrolling for Winamp Modern skin pledit winshade
* Improved: Vista elevation (fixes: installing skins, filetype reg, Pro reg)
* Improved: Zero padding option for playlist item numbers
* Improved: [in_flv] Better streaming support and other improvements
* Improved: [in_mp3] Added APEv2 tag options to configuration
* Improved: [in_mp3] Optional retention of existing APEv2 headers
* Improved: [ml_disc] Artwork support for Data CD Reader
* Improved: [ml_disc] Better detection of any copy operations in progress
* Improved: [ml_disc] Improved start times if ml_disc view is active
* Improved: [ml_local] Redesigned 'Show Info' panel
* Improved: [ml_nowplaying] Redesigned 'Now Playing' artist experience
* Improved: [ml_playlists] Right-click option to sort list of playlists alphabetically
* Improved: [pmp_usb] Connect/Disconnect/Blacklist config options
* Fixed: Alt+F4 closing Winamp instead of individual dialogs
* Fixed: Bento browser redirecting network drive url's to Winamp Search
* Fixed: Blank playlist when in docked toolbar mode and Winamp is minimized
* Fixed: Modern skin component windows appearing individually in Alt+Tab
* Fixed: Multi-flashing on startup when previously closed whilst minimized to systray
* Fixed: Pure Virtual Function Call runtime crash errors
* Fixed: Redraw issue when built-in classic vis is disabled
* Fixed: Various multi-monitor docking issues
* Fixed: Various other 5.53-specific keyboard accelerator issues
* Fixed: [Bento] Drag+Drop into Playlist from Open Files dialog
* Fixed: [burnlib] 'CD Drive locked by another Winamp process' on 2nd burn attempt
* Fixed: [burnlib] 'Burner releasing failed' error
* Fixed: [dsp_sps] Crash on close when config Help dialog is still open
* Fixed: [enc_flac] MD5 checksum generation
* Fixed: [gen_ff] Attached vis plugin crash on winshade to normal mode in Modern skin
* Fixed: [gen_hotkeys] Assigning Winkey with already used Ctrl combinations
* Fixed: [gen_ml] Enter/Shift+Enter broken for ML treeview items (5.53-specific)
* Fixed: [in_cdda] Composer/Conductor logic bug when saving CDDB data to database
* Fixed: [in_flac] Minor metadata writing bugs
* Fixed: [in_midi] Seeking with 'DM/MS Synth' device in Streamed playback mode
* Fixed: [in_mp3] Crash on files with invalid/corrupt gapless data
* Fixed: [in_mp3] Create new ID3v1/v2 tags configuration setting
* Fixed: [in_vorbis] Huge lag on files with large embedded cover art
* Fixed: [in_vorbis] Metadata & Format Info display for streams in View File Info
* Fixed: [in_vorbis] Potential unicode-related crash on open/close issue
* Fixed: [jpeg.w5s] Saving corrupt album art
* Fixed: [ml_autotag] Results dialog hidden under Winamp when AOT is enabled
* Fixed: [ml_disc] Small resource leak
* Fixed: [ml_playlists] Enter/Shift+Enter broken for selected ML Playlist items
* Fixed: [ml_playlists / ml_transcode] Sending playlists from ML tree to Transcoder
* Fixed: [ml_wire] 404/timeout with valid rss feeds on Vista
* Misc: Miscellaneous localization tweaks, fixes & updates
* Misc: More miscellaneous general tweaks, improvements, fixes and optimizations
* Misc: Setup fixes (Agent not always starting, WLZ filetype not registering, etc)
* Misc: Various other 'Winamp Modern' & 'Bento' skin updates
* Misc: [enc_flac] Now encodes using libFLAC instead of Flake
* Updated: Bento skin v1.2
* Updated: freetype 2.3.7
* Updated: libpng 1.2.28
* Updated: [enc_lame] LAME 3.98
