Winamp 5.33 disponible - Actualités informatiques - NDFR.net
Ce soir Nullsoft décide de sortir une nouvelle version de Winamp après pratiquement 3 mois de gestation.
Il s'agit de la version 5.33 qui apporte l'unicodisation de la librairie multimédia (une conversion est faite et est IRRÉVERSIBLE).
Si vous passez à cette version, il faudra y rester ou vous perdriez votre librairie.
Changelog de la version 5.33
* Improved: [gen_ml] unicode tree item title support
* Improved: [NDE] speed optimizations
* Improved: [ml_history] localized dates
* Improved: [ml_local] Unicode media library support
* Improved: [ml_playlists] now uses m3u8 to retain unicode file info
* Improved: [ml_playlists] playlists in send-to submenu
* Improved: [ml_pmp] playback-from-device of unicode filenames
* Improved: [ml_wire] moved discover page to main page
* Improved: [pmp_p4s] auto-detection of supported file formats
* Fixed: playlist directory loading fix (again)
* Fixed: recursive playlist loading
* Fixed: video lockup when switching video display settings
* Fixed: HTML playlist generation
* Fixed: temp file cleanup after burning
* Fixed: Alt+L from video window
* Fixed: fullscreen video display drawing glitch
* Fixed: recursive shortcut loading
* Fixed ASX Loader not reading local relative paths correctly
* Fixed: [gen_ml] & needs expanding to && for any menu entries showing filenames
* Fixed: [in_flac] not saving genres.txt in multiuser directory
* Fixed: [in_mp3] create id3v2 tag when writing album artist
* Fixed: [in_mp3] workaround for id3v2.4 tags with badly formatted frame sizes
* Fixed: [in_vorbis] writing blank metadata instead of erasing
* Fixed: [in_wave] sometimes not remembering custom extensions
* Fixed: [in_wm] stack overflow on hi-def multichannel audio with replaygain enabled
* Fixed: [in_wm] File Info editor album artist not saving
* Fixed: [ml_local] Modern skin pledit winshade 'Manage Playlist' button bug
* Fixed: [ml_local] ignoring files with ellipsis (...)
* Fixed: [ml_local] editing disc via 'edit selected items'
* Fixed: [ml_local] sorting fix
* Fixed: [ml_local] ratings menu
* Fixed: [ml_local] crash when sorting by replaygain
* Fixed: [ml_local] deadlock when retrieving title to guess metadata
* Fixed: [ml_local] no longer causes unicode files in playlist to display ?????
* Fixed: [ml_playlists] time column and 'status' in statusbar
* Fixed: [ml_pmp]
* Fixed: [ml_rg] multi-channel files being calculated incorrectly
* Fixed: [ml_transcode] bad/missing metadata on transcoded files
* Fixed: [ml_transcode] error on overly long filenames (can't open destination file)
* Fixed: [ml_wire] podcasts that change titles not updating properly
* Updated: Coding Technologies aacPlus encoder 8.0.3
Télécharger Winamp 5.33 Full EMusic (6.4 Mo, la version Full normale n'est plus disponible)
Télécharger Winamp 5.33 Lite
6 commentaires pour “Winamp 5.33 disponible”
  1. Cougar a dit (le 14 février 2007 à 00h14)
    et ça apporte quoi cette unicodisation ?
  2. 1for-matik a dit (le 14 février 2007 à 01h14)
    Originellement posté par Cougar Afficher le message
    Si tu as des fichiers genre pr0n russe avec une nom de fichier en cyrillique ou une chanson écrit en japoniais, ça peut aider
  3. Cougar a dit (le 14 février 2007 à 09h30)
    Dans ce cas ça m'intéresse (jvous laisse trouver lequel des trois )
  4. Matt a dit (le 14 février 2007 à 11h54)
    Originellement posté par 1for-matik Afficher le message
    Ca sent le vécu ^^
  5. 1for-matik a dit (le 14 février 2007 à 12h13)
    Originellement posté par Matt Afficher le message
    Ca sent le vécu ^^
    Je le savais que j'aurais une reflexion comme celle-là ^^
    Mais met toi dans la peau des millions d'utilisateurs de Winamp sur cette bonne vieille terre
  6. streets a dit (le 16 mars 2007 à 09h43)
    sortie de Winamp 5.34 Beta, Build 1155
    Winamp 5.34 Beta
    * New: IPv6 support
    * Improved: Made installer delete in_mp3pro :/
    * Improved: IPC_CONVERTFILE now uses api_decodefile (for ripping & transcoding)
    * Improved: Embedded IE pages now run in a separate thread
    * Improved: General speed and performance optimizations
    * Improved: [in_wave] Added ATF support for %bitrate%
    * Improved: [ml_local] Composer / Album view (in Edit View, Filters tab)
    * Fixed: ???? in the taskbar & system tray with Unicode titles (note that many third party plugins will cause this to revert back to ????)
    * Fixed: Installation of Sonic Engine on systems with other Sonic/Roxio products
    * Fixed: Tab orders in Preferences
    * Fixed: Various media library accessibility/focus issues
    * Fixed: [enc_lame] Better output samplerate selection for transcoding
    * Fixed: [enc_wav] WAVs missing first 11 samples
    * Fixed: [gen_ml] Keyboard focus issue
    * Fixed: [in_cdda] Long artist/albumartist CD Info bug
    * Fixed: [in_cdda] Crash on Winamp exit after playing Audio CD
    * Fixed: [in_cdda] CDDB crash-on-close bug
    * Fixed: [in_dshow] potential crash on corrupt/malformed media files
    * Fixed: [in_mp3] Memory leak when retrieving info for .aac files
    * Fixed: [in_vorbis] Album tag removed when using ml 'edit selected items'
    * Fixed: [in_wm] Crash when trying to burn WMA files
    * Fixed: [ml_local] Composer tag not saving with 'Edit Info'
    * Fixed: [ml_local] Total size not showing up in local media views
    * Fixed: [ml_local] Possible duplicate entries on upgrades after rescanning folders
    * Fixed: [ml_local] (No Album Artist) & (No Publisher) sometimes displays no results
    * Fixed: [ml_local] Sorting Album pane by Year
    * Fixed: [ml_local] isempty/isnotempty for querying empty/populated fields
    * Fixed: [ml_pmp] Possible crash when deleting a group of songs containing non-sequential duplicates
    * Fixed: [ml_pmp] "haven't" typo in prefs
    * Fixed: [pmp_p4s] Launching Winamp on device insertion not working
    * Fixed: [pmp_p4s] No longer creates .alb files on devices that don't support it
    * Updated: in_vorbis to libvorbis 1.1.2 and libogg 1.1.3
    * Updated: in_flac 2.0 (based on FLAC 1.1.4)
    * Updated: MusicIP Mix (formerly Predixis MusicMagic) v1.1
    * Updated: Sonic Ripping/Burning Engine v3.6.36.500
Afficher l'actualité “Winamp 5.33 disponible” sur le forum
