Winamp 5.03 - Actualités informatiques - NDFR.net
Bien que pas encore annoncée sur le site officiel, la dernière version de Winamp, la 5.03, est disponible sur le site de téléchargement de Nullsoft.
Le changelog :
  • made MP4 AAC the new default ripping encoder
  • fixed a crash bug when playing some AVI files in in_dshow
  • added multimedia keyboard keys in global hotkeys default configuration
  • added "Manual playlist advance" in Repeat button popup menu in Classic mode
  • improvements in MP3 encoder configuration (added --alt-preset standard, etc...)
  • made the tabs in the preferences XP correctly themed under Windows XP
  • revamped the Media Library preferences a bit
  • new experimental WMA9 input plugin
  • gen_jumpex updates from DrO
  • added "Nuke library" action in Media Library
  • more upside down videos fixes
  • fixed crash if a plugin generated a pledit wm_windowposchanged on shutdown
  • fixed crash exploit in in_mod (thanks Peter Winter-Smith)
  • fixed various crashes in in_midi when playing invalid files
  • made in_midi store its settings in winamp.ini instead of the registry
  • fixed error during installation on computers with chinese/oriental regional settings
  • removed AOD from installer
  • added Shift-R to toggle manual playlist advance
  • updated VP6 video decoder to latest VP6.2 code
  • fixed crash when launching winamp with very long filenames from explorer
  • made registration dialog to appear in Explorer's taskbar when installing pro version
  • fixed pledit/video windows showing up at startup when minimized
  • modern skins updates:
    • winamp modern skin now uses a 3 state repeat button: no repeat/repeat all/repeat track
    • added appplication desktop toolbars capabilities for layouts, add
      appbar="left|top|right|bottom" to use them
    • upped maki binary version, improved stack protection
    • current skin version number is 1.2 (this should not change for a long while now, and of course we continue to support 0.8 to 1.1)
    • (very) limited maki debugger (for now you can bring it up with invokeDebugger(); in a script then use 'x' to continue and 'i' to trace into)
    • fixed obscure capture problem with dragging windows
    • fixed rectrgn being forced to 1 in xml xuiobject buttons that are originally imageless
    • fixed hilited state not on after clicking on buttons while the mouse stays in area
    • fixed scripted onEnterArea/onLeaveArea not being always correctly called while mouse button stays down
    • fixed getToken being passed NULL throwing guru
    • fixed clipping of painting within the background's region of a group rather than within the composed region (the one you can change with sysregion)
    • fixed image cache problem when using the same bitmap as a map and a button image parameter
Télécharger Winamp 5.03 Full (4,20 Mo)
Télécharger Winamp 5.03 Lite (649 Ko)
Source : Neowin.net
13 commentaires pour “Winamp 5.03”
  1. Fred a dit (le 25 mars 2004 à 19h05)
    Domage que Winamp2 ne soit plus mis à jour, Winamp3 est trop gourmand pour tourner correctement sur ma machine, et intègre des tas de fonctions dont je n'ai pas besoin ...
  2. streets a dit (le 25 mars 2004 à 19h34)
    Originellement posté par Fred
    il parle de winamp 2+3
    euh 5.03 plus exactememt
    donc la 3 aux oubliettes
  3. Matt a dit (le 25 mars 2004 à 19h38)
    Oui, mais la 5 aussi est bien plus lourdes que la 2 ... Chez moi elle met plusieurs secondes à s'afficher, alors que WinAmp 2 s'affichait quasi-instantanément ...
  4. LeMoi a dit (le 25 mars 2004 à 19h40)
    toujours aussi lente que la 5.02 ? moi g complètement abandonné, g laissé au cas ou, mais foobar2000 c le top
  5. KnuX a dit (le 25 mars 2004 à 20h05)
    Personnellement je n'ai eu aucun soucis avec la version 5.x hormis le "Always on top" qui laiss(ait/e) à désirer, et parfois un winamp.exe encore présent dans les processus malgré qu'il soit fermé (j'avais ça sur la 2.x).
    Je viens d'installer cette nouvelle version
  6. streets a dit (le 25 mars 2004 à 20h28)
    je dirais meme plus foobar 2000 c'est le top
    +mpc pour la video
  7. Fred a dit (le 25 mars 2004 à 22h24)
    Originellement posté par streets
    Excusez le lapsus, je voulais bien entendu parler de la v5, qui est trop lourde pour nous autres, pauvres petites configs auquelles la v2 suffit amplement
  8. Matt a dit (le 25 mars 2004 à 23h27)
    Même sur des configs plus musclées, la 2 reste nettement plus agréable à utiliser ... J'pense que j'vais pas tarder à y retourner ^^
  9. dubois a dit (le 26 mars 2004 à 09h41)
    restez en version 2 c'est mieux et légé
  10. 1for-matik a dit (le 26 mars 2004 à 10h17)
    Originellement posté par dubois
    Moi je reste à la version 5, beaucoup plus agréable à l'oeil
  11. benoit1024 a dit (le 28 mars 2004 à 08h36)
    la 5 à tout de même pas mal de bonne fonctionnalités et est pour ma part très stable.
    la médiathèque est top
  12. whynot a dit (le 28 mars 2004 à 11h12)
    Hmmm... si wa5 est lent, c'est aussi à cause des "moderns skins" et des tonnes de fonctions -inutiles pour certaines- qu'il trimbale...
    En mettant un bon vieux skin wa2 et en désactivant quelques plugins c'est déjà un peu moins lourd à lancer et ça devient supportable en utilisation mémoire.
    Ceci dit, j'ajouterais que foobar2000 c'est le top.
  13. gelflings a dit (le 3 avril 2004 à 01h13)
    bonjour à tous
    en ce qui concerne Winamp je comprends pas pourquoi vous n'instalez pas la 5 (5.03) et dans l'install vouss virez l'agent , les skins moderne et autre conneries que vous n'aimez pas genre raccourcis claviers tout ça, la video etc
    Car la mediatheque est top et winamp le coeur est vraiment optimisé maintenant
    faites le tests (avis aux amateurs de la 2) vous serez satisfait je pense
Afficher l'actualité “Winamp 5.03” sur le forum
