Au menu des nouveautés (en anglais) :
[options ajoutées]Pour télécharger cette version il suffit de se rendre sur la page de téléchargement et pour plus d'informations sur le logiciel, sur le site officiel.
* Made 'autodetect additional segments by filename'
option sticky.
* Removed trackbar ticks when ticks are a solid bar
to speed up edits on very long timelines.
* Added option to disable use of DirectX in video
displays under Preferences/Display.
[erreurs réparées]
* Fixed odd lock-to-keyframe behavior with edit lists
that have out of order segments.
* Fixed move-to-next-keyframe command at end of time-
line.
* Fixed decompression of 1-bit and 4-bit uncompressed
AVI files under Windows 95/98.
* Audio compression dialog showed the wrong set of
valid formats if a precision was selected under
Audio Conversion.
* The current edit list is no longer applied to batch
jobs created from entire directories.
[régressions réparées]
* Fixed display crashes with odd-width images.
* Segment loading wasn't hopping across drives to pick
up segments from a multisegment capture, as directed
by the AVI's segment hint block.
1 commentaire pour “VirtualDub 1.5.9 build 18121”
