Les nouveautés apportées par la version 11.00 (en anglais)
* Code Folding
* HTML toolbar
* Copy/append line if no selection
* Other minor changes
* Code Folding
* Fold any Function or Structure (C/C++)* Syntax highlighting for multiple languages in a single file
* Collapse All and Expand All
* HTML toolbar
* Preconfigured for most popular functions* Tools toolbar
* Enhanced Color Selector* Enhanced Configurable Menus / Toolbar support
* CSS Style Builder
* HTML Tidy Configuration interface
* Globally Unique ID Number Generator
* Number Converter (selected number to binary, octal, decimal or hexadecimal)
* Artistic Style formatter
* Easier to use* Enhanced User Interface
* Save configurations
* Multiple configurations, select for appropriate task
* Framework/window changes* File Logging
* Improved bookmarks
* Ruler guide for caret position
* "Explorer" style File Tree view
* Improved document tabs
* Automatically update log files at configurable interval* Enhanced brace matching
* Files can individually be set to be log files
* New highlight based on Line/Col Background* Enhanced Spelling Checker
* User configurable match strings
* Aspell spelling checker* HP 3000 with VeSoft FTP support
* More dictionaries available
Description complète sur le site officiel
Voir quelques captures d'écrans
Télécharger UltraEdit v11.00 installation, version ZIP (pas encore de version française)
15 commentaires pour “UltraEdit v11.00”
Merci Lemoi
Quoi que PSPad a quelques atouts non négligeables.
Mais cette histoire de code retractable c'est vraiment pas mal du tout !
A tester !!!
Bref un excellent soft ...
Bon je vais pas ternir ta news lemoi
enfin du nouveau, j'aime bien cette version
* v11.00a addresses all the issues provided in the hotfix plus other minor issues.
* An enhancement to multi-language syntax highlighting will follow in a later release expected within the next few weeks.
* The following items have been addressed:
___*Several project related issues including refresh
___*Only partial project path showing in project list in some instances
___*File Tree View no longer access floppy/removable drives with mouse over
___*File Tree View did not display drives created using the SUBST command
___*Files with an .s03 extension show up as .s0303 in the File Tree View
___*Undocked windows (File tree view and others) now remember if they are undocked when closed
___*The HTML-Toolbar function Text2HTML did not support some conversions
___*HTML Bookmark button changed to anchor to avoid confusion
___*HTML "B"(old) button undo did not remove the <B> tag
___*Added more Icons to toolbar configuration.
___*Toolbar position not saved in some conditions
___*Fixed issues with capture output from tools not always working
___*Output window fixes
___*Function list not always detecting functions that previous versions detected
___*Some functions not showing if function strings ended with asterisk (*)
___*Fixed display issues with line numbers being clipped
___*Fixed display issue with themes/manifest files.
___*Configuration changes to spelling checker options did not always activate "apply"
___*Support Ctrl-B brace matching on non-syntax highlighted files
___*Fixes for multi-line strings
___*Added default folding strings for XML
___*Very slow drawing of XML files with very large lines
___*Crash on save if it's a new file that is syntax highlighted
___*Escape for Auto Complete dialog
___*Positioning problem with spell checker and Unicode file
___*Crash with GUID used multiple times at beginning of file
___*Insert color default color issue
___*Icons left in system tray when UltraEdit closes and minimized to system tray
___*Auto correct on return key
___*Several minor FTP/SFTP issues including MVS.
___*Other minor fixes.
http://www.ultraedit.com/updates/uehotfix.html
Mêmes liens que précédents
- Fixed intermittent scrolling crash
- Fixed extra new line issue when replacing with regular expression
- Changed compare function to not minimize all other open files
- Fixed font increase/decrease irregular point size behavior
- Changed EBCDIC to ASCII conversion to more closely match expected behavior
- Fixed syntax highlighting and function list parsing for FTP files
- Files opened via the explorer context menu will now be detected as read-only correctly
- The ESC key will now cancel out of the FTP Accounts dialog instead of saving
- Added EBCDIC and create CTAGS to available toolbar commands
- Files opened via FTP will now remember their ASCII/BINARY type when saved
- FTP fixes for Stratus VOS
- Fixed print/print preview of syntax-highlighted files
- Fixed syntax highlighting issues with multiple languages in single line
- Added INI setting for old style Windows file list management
- Fixed cursor positioning problem with Chinese font
- Other minor fixes
mêmes liens que précédents
Il doit être trop dépendant de KDE à mon avis aussi.
