Deux nouvelles versions de SyncBack viennent de sortir ! Il s'agit de SyncBack v3.2.7 "SE" qui est proposé à 15$ et SyncBack v3.2.7 qui lui reste gratuit.
La version payante intègre les fonctionnalités décrites ci-dessous :
- Copie des fichiers verrouillés/ouverts
- Option sauvegarde rapide
- Filtre ZIP
- Nouveau moteur FTP
- Amélioration des performances du moteur FTP
- Support des chiffrages SSL 2.0, SSL 3.0 et TSL 1.0
- Support des mots de passe utilisables une seule fois
- Support de la compression en MODE Z
- Support de la commande XCRC
- Support des nouvelles fonctions FTP (par exemple MLSD)
- Meilleur support des pare-feu/NAT.
- Plus de fenêtres pour rappeler la fin de l'évaluation
- Utilisation légale au-delà de 15j
Les nouveautés de la version 3.2.7 "SE" et "basic" :
- New -shutdown command line parameter
- Aborting an FTP transfer is now much quicker
- If a folder cannot be created an error message on the reason is returned
- Semi-colons can now be used in filenames with compression
- HTML log file colours changed
- Fixed index out-of-bounds error (was related to columns in tree)
- FTP profiles are not aborted before their time-out setting (was previously set to 30 seconds)
- Stop button on tree is ghosted instead of disappearing when stop button is pressed
- Empty zip files (when using single file compression) are correctly deleted
- Compression progress shown when using multi file compression
- By default, new profiles will not use the Windows shell for file copying and deleting
- By default, new profiles will have Passive enabled for FTP
- By default, new profiles will not be disconnected from network shares after a profile is run
- If a form doesn't appear on the screen (e.g. resolution is lower) then it will be reset to appear on screen
- A new version of SyncBack cannot be installed while it is running
- Changed the way empty folders are created/deleted
- Fixed Profile export (it was not exporting strings with double-quotes in them correctly)
- Included support for any future Greek translation
- Help file updated
Pour rappel, ce petit freeware/shareware en français est un outil de sauvegarde qui permet d'effectuer des synchronisations de fichiers ou de répertoires (mirroring) en local (autre emplacement sur le disque, CD-RW, CompactFlash...) ou sur un réseau (serveur FTP, disque partagé....). Au lieu de copier bêtement l'ensemble des fichiers à chaque sauvegarde, il se contente d'ajouter les fichiers manquants et de mettre à jour ceux qui sont modifiés.
Des profils de sauvegarde sont proposés qui permettent d'effectuer des backups simples ou récursifs, des synchronisations simples, récursives ou à double sens, mais l'utilisateur pourra aussi ajuster chaque paramètre pour personnaliser le travail. Lors d'une synchronisation, il est par exemple possible de se baser sur la date des fichiers (peu précis) ou sur leur contenu (très précis).
On programme les sauvegardes par l'intermédiaire du planificateur de tâches de Windows qui est intégré au logiciel et une fonction de simulation permet de s'assurer que la procédure de backup est correcte avant de la mettre en production.
Télécharger SyncBack v3.2.7
Télécharger SyncBack v3.2.7 SE (limité à 15 jours d'utilisation)
Site officiel
1 actualité similaire
  1. Logiciels SyncBack v3.2.6
Afficher l'actualité “SyncBack v3.2.7 SE” sur le forum
