Au sommaire de cette mise à jour, amélioration du support du 64bits, du multi-core virtuel, de la 3D virtuelle et corrections d'autres petits bugs et régressions.
Voici la liste de toutes les corrections de cette version :
VirtualBox 3.0.4 (released 2009-08-04)
* VMM: 64 bits guest stability fixes (AMD-V only; bugs #3923 & #3666)
* VMM: SMP stability fixes (AMD-V only)
* VMM: SMP performance improvement (esp. for Solaris guests)
* VMM: eliminated several bugs which could lead to a host reboot
* VMM: fixed OS/2 ACP2 boot floppy hang (VT-x only)
* VMM: small performance improvement for OpenSolaris guests (AMD-V only)
* VMM: fixed CentOS/Xen reboot (software virtualization only; bug #4509)
* SATA: fixed hangs / BSOD during Windows XP installation (bug #4342)
* SATA: mark the ports as non hotpluggable (bug #3920)
* 3D support: fix deadlocks and context/window tracking for multithreaded applications (bug #3922)
* 3D support: fix memory leaks when terminating OpenGL guest applications
* 3D support: fix crash in Call of Duty
* NAT: using two or more NAT adapters in one VM was broken (3.0.0 regression)
* NAT: fixed network communication corruptions (bugs #4499, #4540, #4591, #4604)
* NAT: fixed passive ftp access to host server (bug #4427)
* iSCSI: fixed cloning to/from iSCSI disks
* GUI: fixed path separator handling for the OVF export on Windows (bug #4354)
* GUI: the mini toolbar was only shown on the first host display (bug #4654)
* GUI: added a VM option to display the mini toolbar on top
* GUI: don’t crash when adding plus configuring host-only network interfaces
* Shared Folders: fixed selection of a drive root directory as a shared folder host path in VirtualBox (Windows host only)
* USB: fixed a bug that may have rendered USB devicefilter settings inactive (3.0.2 regression, bug #466
* Guest Additions: report the Guest Additions version to the guest properties (bug #3415)
* Mac OS X hosts: fix creation of VMDK files giving raw partition access (bug #1461)
* Mac OS X hosts: improved support for Snow Leopard
* Linux hosts: fixed problems leading to wrong colors or transparency in host windows with some graphics drivers (bug #3095)
* Linux hosts: hardware detection fallbacks if the hal service fails to find any DVD drives.
* Linux and Solaris hosts: Work around color handling problems in Qt (bug #4353)
* Solaris hosts: fixed memory leaks in host-only networking
* Solaris Installer: fixed incorrect netmask for Host-only interface (bug #4590)
* Solaris Installer: added package dependency for Python and Python-devel (bug #4570)
* X11 guests: prevent windows from being skipped in seamless mode KDE guests (bugs #1681 and #3574)
* X11 guests: fixed screen corruption in X11 guests when large amounts of video RAM were allocated (bug #4430)
* X11 guests: some fixes when switching between host and guest-drawn mouse pointers.
* X11 guests: fixed an issue which caused seamless mode to stop working as it should (the main issue listed in bug #2238 ).
Télécharger Sun xVM Virtualbox 3.0.4 pour tous les systèmes d'exploitation
