Sun xVM Virtualbox 2.2.2 - Actualités informatiques - NDFR.net
Un peu moins d'un mois après la sortie de la version majeure de VirtualBox, Sun nous propose aujourd'hui la 1ère mise à jour mineure de la version 2.2.
Cette mise à jour est destinée à corriger les couacs rencontrés lors de l'installation de la 2.2 notamment les cartes réseau non détectées, le DHCP non reconnu dans les systèmes virtualisés Windows et l'ajout du support préliminaire de Mac OS X Snow Leopard pour nos chers amis adorateurs de la Pomme (en système hôte bien entendu).
Le reste des corrections est listé ci-dessous grâce au changelog :
VirtualBox 2.2.2 (released 2009-04-27)
* Host and guest clipboard: fixed a number of issues affecting hosts and guests running the X window system.
* Guest Additions: make sure the virtual mouse autodetection works on first reboot after installing the Additions on X.Org server 1.5 and later.
* Guest Additions: properly report process identity number of running services
* Guest Additions: clean up properly if the X Window server terminates
* Linux Additions: fixed installation path for OpenGL libraries in some 64-bit guests (bug #3693)
* Solaris Additions: fixed installation to work when X.Org is not installed on the guest
* Solaris Additions: fixed a bug that could panic the guest when unmounting a busy shared folder
* Windows Additions: fixed mouse pointer integration of some Windows guests (2.2.0 regression, bug #3734)
* Windows Additions: fixed installation on Windows Server 2008 Core (bug #262
* Main: do not try to use older versions of D-Bus (Linux hosts only, bug #3732)
* VMM: fixed out-of-memory conditions on Windows hosts (bug #3657)
* VMM: fixed occasional hangs when attaching USB devices during VM startup (2.2.0 regression; bugs #3787)
* VMM: fixed guru meditation related to memory management (software virtualization only)
* Virtual disks: fix possible data corruption when writing to diff images, incorrect detection of redundant writes
* GUI: reworked network settings dialog
* GUI: properly show the detailed settings dialog of NAT networks (bug #3702)
* GUI: HostKey could not be changed (2.2.0 regression, bug #3689)
* GUI: fixed memory textfield size (Windows hosts only; bug #3679)
* GUI: fixed crash when selecting a shared folder path (Windows hosts only; bugs #3694, #3751, #3756)
* VBoxManage modifyhd --compact: implemented again for VDI files, and now supports relative paths (bug #2180, #2833)
* VBoxManage snapshot discard: made it work again (2.1.0 regression; bug #3714)
* NAT: on some Windows host, the guest didn’t receive a DHCP lease (bug #3655)
* NAT: fixed release assertion during poll() (bug #3667)
* Clipboard: fixed random crahes (X11 hosts only, bug #3723)
* Shared Folders: fixed incorrect permissions for Solaris guests
* Shared Folders: fixed wrong file sizes with Solaris guests
* CBindings: fixed possible memory leak while releasing the IVirtualBox and ISession Objects
* Solaris hosts: fixed host-only network interface incompatibility with nwam/dhcpagent (bug #3754)
* Windows installer: fixed several install and uninstall issues (bugs #3659, #3686, #1730, #3711, #3373, #3382, #3701, #3685, #3710)
* Mac OS X hosts: preliminary support for Snow Leopard
Télécharger Sun xVM Virtualbox 2.2.2 pour tous les systèmes
Afficher l'actualité “Sun xVM Virtualbox 2.2.2” sur le forum
