Les changements
improved Contact Importers
Voicemail subscribers can leave voicemails to anyone
animated emoticons
missed events panel
services panel
possibility to send multiple auth requests from one window
Arabic, Hungarian, Bulgarian, Czech and Turkish languages added
improved Profile
main menu -> help -> getting started wizard
automatically answer the call option is back
easier getting started wizard
VM options visible to everyone
Receive contacts: requesting authorization through one single form
removed calltab toolbar
added hold and mute buttons to toolbar
improved chats and calls connectivity behind proxy
improved logging in behind proxy
improved Central Contact List
if a SkypeIn call is sent to voicemail, custom greeting is played
multiple language support in search
trayicon did not always respond correctly to doubleclicks
cannot delete speeddial
close the search tab if no results found
status not updated when USB phone is used
accessibilty - extra large fonts support improved
some login and startup related issues cleared
options: Sound Alert keeps playing
could not bookmark a chat without topic
call history context menu 'listen' is now visible only on voicemails
rare access violation in 'Manage blocked users'
Télécharger Skype 1.3.0.28 Beta (7 Mo)improved Contact Importers
animated emoticons
missed events panel
services panel
improved Profile
Site officiel : Skype
Source : Major Geeks
3 commentaires pour “Skype 1.3.0.28 Beta”
02.06.2005 version 1.3.0.29 Beta
* change: new splash and About images
* change: new language files
* bugfix: Import Contacts: no valid importers found from path
* bugfix: Import Contacts: if no contacts found, window is not brought to front
* bugfix: voicemail options broken if voicemail subscription expired
Pour le télécharger voir le lien de la news
Source : Skype
10.06.2005 version 1.3.0.41 Beta
* known issue: when you have chatted a lot, new version startup might take several minutes
* known issue: crashes on Windows 98
* bugfix: removed redundant quotes in Send Contacts dialog
* bugfix: access violations when launching Skype in some languages
* bugfix: Skype took 100% CPU on some mashines during startup
* bugfix: access violation if changing language when being logged off
* bugfix: focus was moving in search
* bugfix: Outlook importer did not find all possible e-mails
* bugfix: new profile dialog did not fit to 800x600 screen
* bugfix: search: searching for 50+ did not give any results
Changelog complet ici
Source :Betanews.com
