PE Builder v3.0.33 - Actualités informatiques - NDFR.net
La version 3.0.33 de PE Builder vient de sortir. Pour rappel, PE Builder vous permet de concevoir gratuitement un live CD basé sur votre CD de Windows XP ou Windows Server 2003 en quelques clics de souris. PE Builder s'inspire de WinPE mais il a la particularité d'intégrer une GUI entièrement paramétrable (menu en XML). Grâce au système de plugins il est possible d'intégrer des pilotes spécifiques (contrôleurs disques, stockages externes, cartes réseaux, etc...). Vous l'aurez compris, l'intérêt principal de ce programme résidant dans le fait de concevoir son propre CD de réparation d'urgence...
Liste des changements :
v3.0.33
Changes to pebuilder.exe:
- Completely new user interface. Because of this alot has changed!
- Changed the icon.
- Changed the splash screen.
- When you start PE Builder for the first time, you must agree to the license agreement.
- On first build the windows end-user license agreement (eula.txt) is shown.
- Added "skip building registry" and "skip building files" in the option screen for advanced users.
- Added "Build ISO (F5)" option to the "Builder " menu to quickly rebuild the ISO image.
- New command line options:
-auto -exit -overwrite -verbose -skipregistry -skipfiles -buildiso See help index "Commandline options" for more info.
- PE Builder now returns the number of errors while building as the errorlevel.
- When pebuilder starts building it first completely erases the output folder. This is somewhat dangerous. Imagine what would happen if a user would select c:\windows as the output path. So pebuilder now only accepts an output path relative to the pebuilder directory. For example if you would enter "BartPE" as the output path and pebuilder is located in your "c:\pebuilder" directory the full output path becomes "c:\pebuilder\BartPE"
- A few very small engine bug fixes.
- A lot of other small changes and enhancements.
New items:
- Included a new plugin "zz_peloader" that contains peloader.exe and
peshutdown.exe created by Pierre Mounir (TheTruth). PELoader is a shell loader that removes the resource limits (user resources limit & 24 hour time limit) from BartPE in a legal way, no need for any patches.Thanks Pierre!!!
- New way of adding network drivers. Just create a new folder in "drivers\Net" and drop all vendor nic driver files in that new folder and pebuilder will automatically include those drivers.
- New way of adding storage drivers. Just create a new folder in
"drivers\SCSIAdapter" and drop storage driver files in that new folder. PE
Builder will automatically include those drivers. Please note that PE Builder
needs the drivers "txtsetup.oem" file and it ignores the *.inf driver files.
- Added a slipstream dialog that helps less advanced users to slipstream
their windows installation files. See menu "source->slipstream".
Changed items:
- plugin\ghost8, some small changes
- plugin\nu2menu, new version and some small changes to menu xml file.
- split plugin\bartpe and plugin\penetcfg into 2 separate plugins.
- updated penetcfg to v2.20
- removed plugin\nic_xxx, use the new way of adding drivers!
- removed plugin\dsk_xxx, use the new way of adding drivers!
Site officiel : http://www.nu2.nu
Téléchargement : http://www.nu2.nu/download.php?sFile=pebuilder3033.zip
Aides et explications pour les français : http://severinterrier.free.fr/Boot/PE-Builder
Présentation de quelques plugins pour PE Builder : http://www.newdimension-fr.net/article/24/page1.html
The CD Forum : http://www.911cd.net/forums/index.php
Afficher l'actualité “PE Builder v3.0.33” sur le forum
