Changes in Winamp 5.56:
· New: Winamp Orgler plugin - Let's you track, chart & share your listening history
· Improved: [jnetlib] New SSL support for playback of https:// streams
· Improved: [ml_autotag] Fuzzy matches now unchecked by default & marked 'Unsure'
· Improved: [ml_local] New background scanner
· Improved: [ml_online] Various tweaks, fixes & enhancements
· Improved: [ml_pmp] Added support for drag+drop from Explorer to device playlists
· Fixed: iexplore process not ending when browser closed after opened via Winamp
· Fixed: Save EQ preset name duplication bug
· Fixed: [Bento skin] SHOUTcast homepage url's redirecting to Winamp search
· Fixed: [gen_jumpex] Up/down buttons reversed, 'stop after current' & other issues
· Fixed: [in_mod] Crash on some .s3m modules (w.i.p.)
· Fixed: [in_mod] Playback glitch during background transcoding
· Fixed: [in_wm] Decimal point issues in Alt+3 format info
· Fixed: [in_wm] Embedded IE browser for DRM license acquisition
· Fixed: [in_wm] Loading of URLs in WPL playlist files
· Fixed: [in_mp4/libmp4v2] Integer overflow bug with MP4 sample size
· Fixed: [libsndfile] VOC buffer overflow vulnerability
· Fixed: [ml_impex] Read "has video" field from iTunes XML (and write on export)
· Fixed: [tagz.w5s] Hang with $right function in ATF when specified field is empty
· Fixed: [vis_avs] msvcp71.dll dependency
· Misc: Added front.jpg/gif/etc to album art criteria
· Misc: More miscellaneous general tweaks, improvements, fixes and optimizations
· Misc: New omBrowser.w5s shared component for ml_nowplaying, wire & online
· Misc: Removed dashboard (ml_dash) from distribution
· Misc: ml_orb now only installed as part of separate Winamp Remote package
· Updated: [gen_jumpex] JTFE v1.0.5
· Updated: libsndfile 1.0.20
Télécharger Nullsoft Winamp 5.56 Full Français
Télécharger Nullsoft Winamp 5.56 Lite Français
Télécharger Nullsoft Winamp 5.56 Full Multilangues
Supprimer les fichiers définitivement...
Test de la webcam Microsoft LifeCam Cinema
