NDFR : Nouvelle version eMule pour Noël
Décidement, ils ne prennent jamais de repos chez eMule. Une nouvelle version, la 0.24b, viens d'être mis en ligne.
Voici la liste officielle des modifications (en anglais):
Dirus: Fixed a bug that could cause eMule to ask the same person for sources instead of a new person after a set time.
Dirus: Fixed a bug that allowed eMule to respond too often (as often as asked) to source sharing requests, rather than according to our preset limits.
Dirus: Fixed a bug that prevented people who use UDP from getting sources from those with complete files.
Unk: Changing max source per file bug fixed.
Unk: Highest and Release priority bug fixed.
Unk: Search results added to a search list with no tab fixed.
Unk: Some of the connection statistics wasn't updated while not in the statistic window.. Fixed.
Dirus: Made source exchange use compression more aggressively.
Dirus: Fixed crash due to stopped/canceled file corrupting the download list controller and the shared file list.
Dirus: Partial fix for preventing ourselves from being readded to a sourcelist when someone sends us back as a source. (some code by Lord KiRon)
Ornis: Connectionattempts restart when reaching the serverlist-end
Ornis: Added statistics: Clientversions (# of clients using the 4 latest edonkey-/emule-versions) [xrmb] ; server occupation (% of userload on servers with known userlimit)
Dirus: Fixed crash that can occur from a corrupted part.met file.
Dirus: Accepted fix for possible garbage displayed in labels when run with multibyte character set. (by pooz)
Ils vous rappellent toujours que si vous avez des problèmes de revenir à la version précédente. Cependant, ils ont encore un problème, après le départ de Merkur, c'est au tours de Juanjo de quitter l'équipe...
emule.sourceforge.net
1 actualité similaire
  1. Général Nouvelle version de PHP-XS
12 commentaires pour “Nouvelle version eMule pour Noël”
  1. LeMoi a dit (le 25 December 2002 à 15h33)
    tiens charles, tu as changé de nom ?
    sinon, tu n'étaias pas obligé de mettre toutes les nouveautées, mais ç'aurait bien que t'en mettes 2-3 en français, et de dire de voir le reste sur le site officiel ...
  2. claude922 a dit (le 25 December 2002 à 15h51)
    Oui, j'ai changé de nom !
    Et puis désolé, la prochaine fois, je ferais ce que tu m'as dit! Promis!
  3. nikeman a dit (le 25 December 2002 à 19h10)
    salut,
    kkun l'a til essayé ?
    Il est stable ??
    mErci a+
  4. chalouf a dit (le 25 December 2002 à 19h37)
    Oui il est mieux..
  5. nikeman a dit (le 25 December 2002 à 19h50)
    ok j'essaye dés ce soir merci
  6. williamw a dit (le 26 December 2002 à 08h46)
    salut
    je l'ai installé depuis hier pas de probleme, ça tourne bien , quelques modifs sympa aucun plantage, la recherche fonctionne toujours aussi mal mais bon c pas grave
  7. nikeman a dit (le 26 December 2002 à 14h42)
    tu es fou !!
    la recherche est trés rapide, et j'ai toujours trouvé une réponse à ce que je voulais
  8. williamw a dit (le 26 December 2002 à 14h44)
    pourtant je constate une grosse grosse ..... difference avec edonkey
  9. ChatNoir a dit (le 26 December 2002 à 14h58)
    Ca c'est sûr que de ce côté là eDonkey est plus performant (bon, c'est le seul )
    Essaye www.jigle.com nikeman, tu devrais avoir beaucoup plus de résultats.
  10. williamw a dit (le 26 December 2002 à 15h00)
    oui je connais mais c'est couillon d'avoir une option qui ne sert pas à grand chose, c'est clair que edonkey à cet avantage, le seul
  11. Newage a dit (le 26 December 2002 à 18h51)
    moi perso je prefere ma mule que le donkey
  12. williamw a dit (le 27 December 2002 à 07h56)
    pareil
    je viens de retester la recherche avec la 0.24b et bien les resultats sont bien meilleurs qu'avec la 0.22 ( meme recherche sur le meme serveur )
Afficher l'actualité “Nouvelle version eMule pour Noël” sur le forum
