NDFR : mIRC 6.31
Et hop, une version 6.31 vient de sortir avec comme nouveautés, un léger ravalement de facade tant pour le logiciel en lui-même, mais aussi pour le site qui se faisait vieillissant.
Parmis les nouveautés, amélioration du support de l'Unicode etc etc etc...
Changelog de mIRC 6.31
Full list of Fixes, Changes and Additions in mIRC 6.31:
1.Fixed tooltips bug in toolbar.
2.Fixed /background window name bug.
3.Fixed remote.ini scripts folder bug.
4.Fixed dns pool message bug during connect retry.
5.Fixed notify window taking focus every time you connect to a
server. The notify window also no longer automatically closes
when you disconnect from all servers.
6.Fixed tips control codes bug.
7.Fixed if/elseif error display bug.
8.Fixed /window -dh not hiding desktop window.
9.Changed $tip() $null parameters so that they are now optional.
10.Fixed script editor Windows taskbar display bug.
11.Fixed /dll crash bug with self-calling dlls.
12.Fixed on START event not being triggered before all other events
on startup for loaded scripts.
13.Fixed while loop break/continue bugs.
14.Fixed /writeini error handling bug.
15.Fixed ial not being updated by protect/ignore/etc. commands.
16.Added @wid support to /setlayer.
17.Added /tips [on|off] and $tips identifier.
18.Added "Hide tips when locked" option to lock dialog.
19.Fixed editbox/listbox focus bug when switching windows.
20.Fixed $inellipse() bug by enabling floating point consistency
option in compiler.
21.Fixed /hinc bug.
22.Fixed -nouninst backward compatibility bug.
23.Fixed flickering in channel nickname, channels list, and all
other window listboxes.
24.Changed script editor interface slightly, now cleaner and easier
to read. Added Check Bracket/Sort Variables items to Edit menu,
line numbers to margin, and enter/home key indentation support.
No longer flickers when resized.
25.Updated to PNG 1.2.22 and PCRE v7.4 libraries.
26.Fixed double-click on treebar notify nicks bug, now triggers
correct Clicks dialog notify list alias.
27.Fixed on ^filesent/rcvd not /halting text bug.
28.Fixed treebar notify nicks menu not having $1 set as nick.
29.Fixed installer bug with mIRC/help file not being launched on
install completion.
30.Fixed unicode encoding bug when pasting large amounts of text.
31.Fixed unicode not being copied to clipboard correctly from a
@window with no editbox.
32.Changed right-click behaviour in custom dialog listboxes to allow
selecting an item without checking its radio/check box.
33.The default text for /list numerics 321 and 323 can now be halted.
34.Added SSL option to automatically accept invalid certificates.
35.Fixed @window tabs display bug.
36.Tips now shade each alternate message that is added to an existing
tip to make it easier to distinguish individual messages.
37.When bars are locked the drag bars are now hidden from view.
38.Added /abook -h switch to open highlight dialog.
39.Fixed background picture display bug when loading large images.
40.Fixed line width/height measurement bug in @windows, now the same
as non-@windows.
41.Fixed /splay and /sound error display bug.
42.Fixed saving tray/maximized window state bug.
43.Fixed /drawtext clipping bug when using tabs.
44.Fixed tray icon click multi-monitor bug.
45.Fixed reload log files bug when lock log files option is enabled.
46.Fixed Editor "Monitor File Changes" memory bug.
47.Changed behaviour of "Hide minimized desktop windows" option so
that query, message, and chat windows remain visible when they are
first opened minimized on the desktop.
48.Fixed /hinc and /hdec maximum value bug.
49.Fixed clipboard handling bug.
50.Fixed $longfn() routine not appending / slash to the result when
it is a directory.
51.Updated the mIRC icon and over seventy other icons in the toolbar,
switchbar, tray, and window icons.
52.Fixed treebar focus bug when selecting item in treebar while mIRC
is not active application.
53.Fixed some settings in editor dialog not being remembered if it
was closed using the cancel button.
54.Fixed favorites dialog gpf bug when editing folder name.
Télécharger mIRC 6.31
4 actualités similaires
  1. Informatique (logiciels) mIRC 6.2
  2. Informatique (logiciels) mIRC 6.16
  3. Informatique (logiciels) mIRC 6.15
  4. Informatique (logiciels) mIRC 6.12
2 commentaires pour “mIRC 6.31”
  1. Matt a dit (le 02-11-2007 à 13:34)
    Pas mal le ravalement. Ca fait un peu (beaucoup ^^) moins Win3.1 qu'avant
  2. JoE a dit (le 02-11-2007 à 15:11)
    T'as raison ça fait Win98
Afficher l'actualité “mIRC 6.31” sur le forum
