Cette version 4.60(.324) offre de nouvelles fonctions et améliore celles qui étaient déjà présentes dans la 4.50 comme le support des fonctions Plus! dans la fenêtre de conversation Mobile (fonction SMS de WLM), un meilleur support des avatars animés pour WLM 9.0 Bêta sans compter de nouvelles fonctions comme (par exemple) envoyer un fichier sur un serveur FTP ou encore de dézipper une archive.
D'autres nouveautés sont précisées dans le changelog :
Messenger Plus! Live 4.60.324 (19/03/2008 )
* You can now filter yourself out from event logging.
* Mobile Device chat windows are now fully supported by Messenger Plus!.
o Features like Quick Texts, commands, smart tags and previous message recall are now accessible the same way as they are in normal chat windows.
o Logging is fully functional.
o Mobile chat windows are now tabbed too. If you prefer keeping your mobile chats separated from one another, you can use the new TabMobileChatWnds registry setting.
* If too many Plus! notification popups try to be displayed on screen, Messenger Plus! queues the extra windows to be displayed later, when possible (so that notifications aren't displayed out of screen).
* WMA sounds can now be selected for event notifications.
* Fixed: some animated GIF display pics (Messenger 9) display improperly in the Contact Information windows.
* Fixed: /font does not work in Messenger 9 Beta.
* Fixed: some of Messenger Plus!'s own resources are loaded before the currently enabled skin, preventing them to be modified.
* Fixed: a couple of bugs that could cause Messenger to crash in some specific occasions. More stability! always a good thing.
* Fixed: external libraries distributed with scripts that need registration on import (OLE or .NET) fail to register in Windows Vista with UAC on. Messenger Plus! also makes absolutely sure now that the libraries are properly registered before trying to start the script for the first time.
* Fixed: notification popups from Messenger Plus! may steal the focus.
* Fixed: notification windows from Messenger Plus! don't animate depending on your Windows settings.
* Fixed: Messenger may not lock or unlock properly when using several Messenger accounts (polygamy) with the same shortcut specified for locking or unlocking.
* Scripts: a new function called Interop.GetCallbackPtr() has been added. It allows the creation of callback parameters for Windows API calls to functions like EnumWindows.
La suite du changelog
Messenger Plus! Live 4.60 supporte donc WLM 8, 8.1, 8.5 et partiellement la 9.0 bêta sur Windows XP à 2008 32 ou 64bits.Messenger Plus! Live 4.60.324 (19/03/2008 )
Télécharger Messenger Plus! Live 4.60.324
carte mère et le processeur
