Pour rappel, Google Earth est le nouveau nom de Keyhole (cette fois c'est précisé
), basé sur le service Google Maps, le logiciel concurrence de très près le logiciel de la NASA, World Wind.
Changelog de Google Earth Bêta 4
Features
- Share with Google Earth Community option: right click on an icon or
folder and you can quickly share your placemark with folks on the GEC.
(GEC login required)
- overview window size now controlled by a slider, can be up to nearly
one quarter of view
Bug fixes
- confusion at startup with Windows Server 2003 graphics choices
- no longer fly-to all ADDRESS geocoded placemarks
- movie making with small font size might hang
- all network errors should offer offline mode
- network links will offer a dialog box to continue fetching if one fails
- lat/long input now more flexible, supports NSEW and nsew
(Note, the "d" is no longer needed (or supported), just use a space)
Features
one quarter of view
Bug fixes
Télécharger Google Earth 3.0.0529 Bêta 4
Source : Fileforum
20 commentaires pour “Google Earth 3.0.0529 Bêta 4”
j'étais en train d'écrire un message pour te demander pourquoi publier un nouveau sujet pour une évolution mineure (3.0.0464 -> 3.0.0529), qui plus est, en Bêta,mais avant de poster la réponse, j'ai lu l'autre sujet et j'ai vu qu'il a été complètement pourri par un abruti...
M'en vais faire ma mise à jour moi
Bug fixes
- overview window no longer fuzzy, will fetch as needed
- several rare crashes, mostly with bad graphics drivers
- direct URL links to KMZ files in description balloon now work (KML already did)
- custom icons no longer require the size be input, it defaults to the extents of the image
- IMG SRC local image files were not being zipped into kmz (0464 regression, now fixed)
- balloon now resizes to match image width
- hyperlinks in <name> were misleading and have been disabled
- obscure bug in Intel jpg library failed on some AMD processors,
updated library fixes problem (this showed up as "zebra-like stripes")
[ NOTE: "Share with Google Earth Community" still only works with IE... we'll have to fix
this in the next one ]
Cosmetic Change
Installing Google Toolbar for Internet Explorer has been added as an option at the end of
the Google Earth install or upgrade. You'll only be asked once and only if IE is your
default browser and you don't already have Toolbar installed.
Changes between Sept 3rd (.054
Features
- Edit->'Find in "Places"', allows searching for items (Ctrl-F)
- embedded web window now has vertical split option
(works great on wide screen monitors especially for National Geographic)
- embedded web window now has "pop-out" option
- network link icons now reflect status of fetching/failed
- the included (optional) Google Toolbar for Internet Explorer now has a
"search in Google Earth" option. If you already have the most recent
version of IE or FF Google Toolbar installed, restarting your browser
after the GE install should enable the new search option. You may need
to enable it in the Google Toolbar options.
Bug fixes
- Share with Google Earth Community now supports default browser
- reverse geocoding (address lookup) now works in Pro (Ctrl+RightClick)
- standard-quality mode Movie Maker improvements
- network link fetch now admits to understanding KML (allows servers to do the right thing)
- while in full-screen, zooming into Google Campus (and now National Geographic) the
wrong resolution was displayed
- opening empty KML file no longer complains of XML parse error
- a formatting regression in the description balloon has been fixed
Cosmetic Changes
- The size/shape of the search entry area have changed
- Note, the free installer is now called GoogleEarthSetup.exe
Un vestige romain a ete decouvert grace a la vu du ciel dans les environs de Sorbolo, près de Parme.
bon week-end
La localisation d'ovnis ...
http://www.ufomaps.com/
C'est donc avec joie et bonne humeur que je vous annonce ma 6ème news de la soirée concernant Google Earth...
En fait c'est pas trop une surprise vu que je suis dans le topic dedié
Google Earth vient de sortir en version 3.0.0693 Bêta "jeséplukombien"
Malheureusement le changelog n'est pas encore disponible pour cette version mais le sera dans peu de temps ici
Quant au lien de téléchargement, c'est toujours celui-là
est dispo
Quelque chose me dit que j'aurais pas du mettre un .gif comme avatar. :rolleyes:
En tout cas, merci LeMoi, merci Frappr!, merci Google.
Internet n'a pas finit de nous surprendre.
Changes between Nov 4th (.0739) and Nov 18th (.0762)
Bug Fixes
- update to correct new problem with overview map sharpness
- more bad graphics driver protection/documentation
- problem with icons rarely, randomly changing should be fixed
Cosmetic
- removed password-entry from Plus/Pro login (pw no longer required, username+licensekey only now)
