Voici un petit aperçu de l'apparence par défaut :
La liste des changements/nouveautés depuis la RC1:
Les nouveautés : "Server use NAT/Non-routable/Masq IP" (FTP Property Dialog/General) Now FTPRush will update file size first when a file be added to upload queue Now allow modify Max Upload logins at FTP Property Dialog "On Double Click Log Window" (option/mouse action) "On Double Click FTP of Favorite window" (option/mouse action) TLS FXP (FTP Property dialog / SSL) Now FTPRush auto copy selected Log to clipboard "Design PopupMenu of Tray Icon" Customize columns of Window list. ("Main menu"/View) "Rename" menuitem at Favorites window Now "anonymous" with a password allowed Click a Favorite item with CTRL key pressed will add or remove a "-" at login password "Hide History Entry from Favorite dropdown menu" at (Option/Display/Favorites menu) Auto save column width for ListView "Hide Selection when ListView Lost Focus", (option/display) "Mouse Action", at (Options/Display/Mouse Action)Les corrections/améliorations : Start a FXP queue with Dest FTP connecting cause a disconnect Now FTPRush will try to release logins when close a window Auto select the directory name after Create a directory the Auto complete feature of Search Dialog disabled to fix Chinese Input bug Limit download speed did not update after save option dialog "Edit Proxy" Dialog did not load proxy port Now Remote window remember top item position when FTP auto refresh Wrong Disk space status when Disk free space = x.0x GB FTP thread still remember the last socks info when reconnect Now Max/Upload/Download logins take effect asap after modified Mouse button4/5 not 100% working with Back to parent dir When reconnect to FTP, did not cleanup Proxy setting Elapsed time now update when FXP first file Can not save/rename a New FTP Server (since version 451) Now TLS FXP working Can not select Queue item (bug since 044![]() "On Double Click FTP of Favorite window" not 100% working The Search Dialog fix cause other heavy problem so need wait next build "New window with current" did not refresh local folder "Switch server" cause a wrong "no transfer" event Now new window position will always at last Queue filename without ext can not be selected Wrong "Disable" menu status at Favorite window Font of FTP Log was differ with New Log Window FTP propertiy dialog did not save IP List Now FTPRush will not auto check "anonymous" when paste a url at FTP Property Dialog Now Clipboard Monitor will auto disabled when FTP Property Dialog visible. Wrong Tab Order of Proxy Dialog FTP Property Dialog did not load the customized Proxy Setting When close a window maybe cause a AV from Queue thread When deleted a layout from "Save Layout" dialog, Layout menu did not refresh Create a New FTP group or FTP Server at favorite window now auto active the RENAME mode Quick connect FTP URL can not switch current local side to remote side sometimes FTP Server Port now allow from 1 to 99999 Now Import function will not auto restart FTPRush Language ID 986 changed to "986=Hide Selection when ListView Lost Focus" When close a window , FTPRush did not release thread handle.
Télécharger FTPRush 1.0 RC2 (2.7 Mo, version d'essai expirant le 15/07/2004)
Télécharger des skins pour FTPRushNote : les possesseurs d'une licence pour UltraFXP se verront offrir une licence pour FTPRush lors de la version finale :rolleyes:
2 commentaires pour “FTPRush 1.0 RC2”
Voici les changements :
Nouvelles fonctions :
