Dans cette version, le problème des extensions qui se désactivent ou le problème de la machine virtuelle Java non reconnue sont résolus
Bugs corrigés dans cette version 2.0.0.9
* Bug 400406 - Firefox will ignore the “clear” CSS property when used beneath a box that is using the “float” property. There is a temporary workaround JS/CSS code available for web developers with affected layouts.
* Bug 400467 - Windows Vista users will get “Java not found” or “Java not working” errors when trying to load Java applets after updating. To fix this, users can right-click the Firefox icon and “Run as administrator”, then browse to a page with a Java applet — doing this once will fix the problem and permanently restore Java functionality.
* Bug 396695 - Add-ons are disabled after updating. Users can fix this problem by opening their profile folder and removing three files (extensions.rdf, extensions.ini and extensions.cache)
* Bug 400421 - Removing a single area element from an image map will cause the entire map to disappear. There is no workaround available at this time.
* Bug 400735 - Some Windows users may experience crashes at startup. There is no workaround available at this time.
Release Notes de Firefox 2.0.0.9
Toutes les versions sont d'ores et déjà disponibles en téléchargement et par mise à jour automatique * Bug 400406 - Firefox will ignore the “clear” CSS property when used beneath a box that is using the “float” property. There is a temporary workaround JS/CSS code available for web developers with affected layouts.
Télécharger Firefox 2.0.0.9 pour Windows 98/ME/2000/XP/2003/Vista/WS2008rc
Télécharger Firefox 2.0.0.9 pour MacOS 10.2+
Télécharger Firefox 2.0.0.9 pour Unix/Linux
