Sortie de la version 1.50 de ce logiciel, qui permet de tout savoir (ou presque) sur son matériel.
La version Home est gratuite mais assez limitée dans ses fonctions.
Il existe 2 autres versions payantes et plus complète.
Voici le changelog (en anglais) :
The 1.50 release includes the following new features, major improvements and bug fixes:
New Features
- Audit and Change Tracking of Windows Updates
- Extended Remote Monitor module to monitor and control remote processes & services
- Chassis intrusion detection
- Enhanced support for servers and workstations (ECC & ECC scrubbing information)
- GPU sensor and overclock information for ATI Radeon family graphics cards
- New benchmark to measure DRAM memory latency
- Improved Chipset page to provide more accurate information about AMD Hammer systems
- Extended PCI devices information, including support for HyperTransport, PCI-X and PCI Express
- Revised support for Windows XP SP2, including enhanced Bluetooth layer support
- Full Swedish localization
Major Improvements
- Network bandwidth usage optimizations in Remote Monitor
- Improved memory benchmarks accuracy and SMBus code stability
- Improved anti-virus software support for eTrust EZ Antivirus and Vet Anti-Virus
- Support for several new hardware monitoring chips
- Support for ATI Radeon 9250, 9550, X300, X600, X700 and X800 family graphics chips
- Support for nVIDIA GeForce 6200, 6600 and 6800 family graphics chips
- Support for the latest processors including AMD Sempron and Intel Xeon 64
- Support for Socket 775 and Socket 939 platforms
- Enhanced support for AMD PowerNow! and Cool'n'Quiet
- Extended memory timings and overclock information
- PCI Express motherboards and graphics cards support
- Enhanced support for ULi K7, K8 and P4 chipsets
- Detailed chipset information for Intel i910, 915, 925 series and E7221, E7320, E7520, E7525
- Detailed chipset information for nVIDIA nForce4, VIA K8M800 and KT880
- /IDLE command-line option to run EVEREST at idle priority
Major Fixes
- Services and system drivers list under Windows Server 2003
- Several issues under Japanese Windows
- Improved stability under VMware virtual machines
- Intermittent crashes due to DirectX-related issues
- SQL anomalies due to long folder names
- Report Converter converting issues on several pages
- SMART disk health information on VIA SATA controllers
site de l'éditeur : ici
télécharger le logiciel : ici
12 commentaires pour “EVEREST Home Edition 1.50”
  1. childerik a dit (le 14 octobre 2004 à 18h18)
    Je télécharge de suite.
    Sinon, je n'ai pas vu de différences flagrantes entre la version home (gratuite) et la version pro (payante). Mieux, la version home a un module de test de bande passante mémoire que la version pro n'a pas apparement : j'ai pas tout compris là :confused:.
    Edit : testé, et sur la mesure de t° du GPU, lequel croire ? L'onglet Overdrive des catalyst ou bien Everest ?
    Overdrive Catalyst indique 68°
    Everest indique 48°
    :rolleyes:
  2. KnuX a dit (le 14 octobre 2004 à 19h28)
    Mets ta main sur la GPU et estime
    Bizarre quand même cette différence...
    Au fait, une information qui pourrait intéresser quelques personnes (dont moi), cette version gratuite "retire"-t-elle des fonctionnalités par rapport à sa précédente ?
  3. childerik a dit (le 14 octobre 2004 à 20h55)
    Originellement posté par KnuX
    Apparement, c'est tiède : je penche pour Everest (parce que les 68° de l'overdrive, çà me parait beaucoup quand même).
  4. Matt a dit (le 14 octobre 2004 à 21h56)
    Explication simple : les Radeon 9800 disposent de deux sondes de température. L'une, intégrée au GPU, indique la température interne de la puce et c'est cette valeur qui est utilisée dans l'Overdrive.
    La seconde est sur le PCB et mesure la température externe de la puce. C'est apparement cette valeur qui doit être utilisée dans EVEREST.
    Chez moi, avec ATI Tool, qui est capable de relever les deux sondes, j'ai 70° en interne et 51° (ami d'Marseille, ami d'Marseille, lève ton verre et surtout ne le renverse pas ...) en externe.
  5. BeClaude a dit (le 14 octobre 2004 à 23h08)
    Salut à tous
    Matt sur les 9600XT il y a les 2 sondes ?
    Sur la capture on dirait que oui ?!
    Perso apparement j'ai les même valeur !
    Capture
  6. childerik a dit (le 14 octobre 2004 à 23h36)
    Ouais, il y a deux sondes chez moi aussi, et pareil, les t° sont voisines entre GPU et GPU (ambiante) ici. Conclusion : que mesure le GPU (ambiante) ?
  7. Matt a dit (le 15 octobre 2004 à 16h59)
    Bon ben je vais installer EVEREST et regarder ...
    EDIT :
    Voilà le résultat que j'obtiens : Sondes
    Donc à priori, GPU (Ambiante) donne la température externe du GPU.
    Pour GPU, j'ai un peu regardé ses variations dans le temps et comparé aux relevés de l'Overdrive et d'ATITool, pour en arriver à une conclusion simple : il s'agit de la température interne, minorée de 20° (mais alors de là à comprendre pourquoi ...). Peut-être un bug de EVEREST, du à une calibration particulière de la sonde (puisque les températures atteintes par les 9800 sont très élevées par rapport aux températures habituelles des autres composants informatiques, peut-être qu'ATI utilise un calibrage différent).
  8. mustang89 a dit (le 22 octobre 2004 à 12h50)
    Nouvelle mise à jour disponible de ce matin : version 1.51
    Voici le changelog :
    The 1.51 release includes the following new features, major improvements and bug fixes:
    New Features
    - Full Korean localization
    Major Improvements
    - Anti-virus software support for ClamWin Antivirus
    - Support for multi-core (CMP) AMD processors
    - Improved chipset information for nVIDIA nForce2 and nForce4
    Major Fixes
    - CPU clock measurement
    - License expiry issues
    - Identification of high-end AMD processors
  9. childerik a dit (le 22 octobre 2004 à 13h39)
    Au fait, il y a un truc qui m'échappe. Lavalys est une société québécoise basée à Montréal, et sur leur site, il y a la langue anglaise ou hongroise seulement :confused:
  10. mustang89 a dit (le 22 octobre 2004 à 14h49)
    Anglais : proximité des USA et langue "universelle".
    Hongrois : rachat des brevets et des programmeurs d'ex-Aïda32.
    Mais c'est vrai qu'ils pourraient nous sortir un site en québécois
  11. 1for-matik a dit (le 22 octobre 2004 à 14h55)
    A mé moué je ne sé po si ils ont une grande cérvelle pour pensèr à ço
  12. childerik a dit (le 22 octobre 2004 à 17h27)
    Non, je dis çà car beaucoup de québécois sont de fermes défenseurs de la langue de Molière, et j'ai toujours cru qu'il était rare de voir uniquement de l'anglais (c'est-à-dire sans affichage en français à côté) sur un affichage dans le Québec.
    Mais je raisonne aussi pour la ville de Québec et l'aval du St-Laurent. C'est peut-être très différent à Montréal.
Afficher l'actualité “EVEREST Home Edition 1.50” sur le forum
