Après une version 1.25 stable et peaufinée, len0x s'est remis au gros oeuvre sur son excellent programme de compression XviD.
Attention, d'après lui, il y a eu de gros changements et cette beta tient plus de l'alpha...
Changelog :
Originellement posté par len0x
- DUE TO MISUSE OF AUTOGK WITH UNSUPPORTED RIPPING TOOLS, IT'S NO LONGER ABLE TO PARSE IFO FILES, SO ONLY DVDDECRYPTER IN IFO MODE CAN BE USED FROM NOW ON
- AutoGK works now with DGMPGDec 1.0.9
- removed test for alternative field order for PAL sources
- video type and AR is taken from D2V file now
- added support for direct opening of MPEG2 files (VOB/M2V/MPG/MPEG). Enabled by CTRL-F12
- fixed problem of cutting off last few seconds of video during splitting
- installer fixes AVI file association to prevent "Error opening AVI" after comp test
- added option to rip all subtitle streams (only when using external subs)
- message "WinRar is not found" is no longer displayed when internal subs are used
- improved parsing of stream info file
- comp test limit is reduced to 65% for XviD 1.0 (resulting in higher resolution output)
- added more debug info into logs
- indexing/demuxing step has now timeout of 30 min after which job will be aborted to allow the queue to proceed
- subtitle splitting step has now timeout of 5 min after which job will proceed anyway
- bitrate for mono encoding is now always half of the bitrate set on advanced options window
- resizing algorithm chnaged heavily to accomodate upcoming support for different input sources (ITU standard is no longer applied)
- field order, aspect ratio and resolution is now taken during encoding from D2V file
- possible width is increased to 1920
- max quality and target quality modes are using source input width and not predefined width of 720/704
Vous pouvez télécharger cette nouvelle version sur le site officiel.
Source : forum@doom9.org
5 commentaires pour “AutoGordianKnot 1.30 Beta”
  1. Didcreole a dit (le 5 juin 2004 à 14h24)
    J'ai testé la version 1.25 il y a peu de temps.
    J'ai passé plus d'une heure à virer les spywares qui ont été installé avec...
    Donc méfiance, en ce qui me concerne j'ai viré AutoGK par la même occasion.:angry:
  2. whynot a dit (le 5 juin 2004 à 18h44)
    Originellement posté par Didcreole
    Alors là --excuse moi hein-- et ne m'en veux surtout pas, mais
    ou encore
    Plus sérieusement et pour faire court : non.
    On ne doit pas avoir la même notion du spyware. Tu pourrais t'expliquer à propos de ces "spywares" ? Juste comme ça hein, l'auteur participe à des développements opensource (GordianKnot), et est unanimement connu sur les forums de doom9 comme quelqu'un de très respectable.
    Et sans tout ceci, je ne vois aucun spyware dans le répertoire d'AutoGK : BeSweet, DVD2Avi (opensource), VDubMod (opensource) et des filtres.
    Tu parles peut-être des autres installers qu'il lance ? DVD2Avi (déjà mentionné), XviD (opensource) et VobSub (crée par Gabest, le génial auteur de MediaPlayerClassic et d'une tonne de plugins / filtres tous opensource).
    Si tu n'es toujours pas convaincu, passe un coup d'Ad-Aware ou Spybot, 10^1000 contre un qu'il n'y a pas l'ombre d'un malware.
    Donc sans rancune, mais non.
    Et greets à shp13 pour ces fabuleux gifs
    [EDIT] : Oups j'avais pas vu ton nombre de messages, du coup ça fait un peu brutal comme accueil. J'aurais été moins violent si j'avais remarqué que c'était ton premier post. Je te prie de m'excuser, euuuuuuuuuuuh .... ben ..... bienvenue sur NDFR ! . Et sincèrement en plus.
  3. Didcreole a dit (le 5 juin 2004 à 19h50)
    Ta réponse m'a semé le doute. J'ai refait un test et effet je n'ai eu aucun Spyware d'installé...
    Toutes mes excuses pour cette fausse information, l'arrivé de ces salles betes correspondaient pourtant à la date d'installation d'autoGK.
    Moi pas comprendre.
    A+ :confused:
  4. whynot a dit (le 5 juin 2004 à 19h55)
    Y' pas de mal .
  5. Magi-X a dit (le 5 juin 2004 à 20h53)
    t'as de la chance Didcreole
    car c'est vraiment un tres bon prog !! J'en ai tester plusieur pendant plusieurs mois, et c'est vraiment le meilleur !!
Commenter l'actualité “AutoGordianKnot 1.30 Beta”
