Le célèbre logiciel d'encodage Auto Gordian Knot, vient de sortir en version 1.53 beta Update. Ce logiciel vous permettra d'encoder facilement et gratuitement vos DVD au format DivX ou XviD.
hidden options are displayed in the log
files that are being processed are displayed in the log
file mode can work with 24fps sources
added hidden file ".audio_id" to override audio stream in file mode (see hidden_option.txt)
TS sources are handled more properly when opening in AutoGK
Télécharger Auto Gordian Knot 1.53 beta Update (1.51Mo, gratuit)
Source : Free-Codecs.com
5 commentaires pour “Auto Gordian Knot 1.53 beta Update”
  1. Steven a dit (le 6 septembre 2004 à 18h13)
    Et encore une beta, je me suis dit (et aussi grâce à Toitoine^^) que cela ne servai à rien de la newsé.
    Bah voici les changement de la version, AutoGK 1.54 beta
    log file is cleaned up and most of VDubMod scripts logged there can only be viewed when enabled via ".debug" hidden file
    audio stream comments removed in file mode
    muxing options of AC3 audio tracks for ESS-based standalones players changed
    slightly tuned resizing parameters for highly compressible sources
    added PID detection for TS which do not have PAT/PMT via bbSummary (I modified bbInfo 1.9)
    some bugs fixed in handling of second audio in file mode
    60fps progressive sources are now either kelp at original frame rate or restored to 24fps if 3:2:3:2 dupe pattern found
    added one more optional line to ".autocrop" hidden file to specify starting frame for autocrop operation (useful if beginning logo or into has different AR)
    bundled with Avisynth 2.5.5 (works ONLY with it)
    bundled with XviD 1.0.2
    Télécharger AutoGK 1.54 beta (3.29Mo, gratuit)
  2. LeMoi a dit (le 24 septembre 2004 à 20h11)
    enfin une version stable :
    changelog
    - added hidden file option ".adjustsubs" that resize _bottom_ subs so that they are not squashed and in place properly (option works only for burnt-in subs)
    - added support for launching AutoGK Assistant (the same way as Hidden Options Tool via CTRL-F9)
    - info window contains all shortcuts used in AutoGK
    - added missing FDecimate.dll and new KernelDeInt to the installer
    - fixed bug when "all" subs were selected but only first ones were processed (for external subs)
    http://len0x.btothec.com/web3/index....download&cid=1
  3. whynot a dit (le 22 février 2005 à 16h37)
    Déterrage, parce que AutoGK est arrivé à maturité, et un nouveau post n'est à mon avis pas nécessaire.
    On en est maintenant à la 1.92beta, et la dernière version stable est la 1.60.
    Mais le plus important c'est que depuis (à peu près) la version 1.85, AutoGK contient un spyware.
    Il s'agit de DAE, un "BrowserHelperObject" pour IE qui comme tant d'autres récolte des infos et les balance chez maman alias ReponseTarget.
    Pour les non-utilisateurs d'IE, aucun problème, et pour les autres, vous pouvez toujours utiliser ce petit programme, testé et approuvé, qui va virer DAE entièrement de votre système (ou utiliser un anti-spyware).
    Si vous n'en voulez vraiment pas, vous pouvez toujours rester à la version 1.60 qui marche trrrrrrrès bien.
    Thread à propos du spy sur doom9.
    Site officiel.
    Source : forum@doom9.org.
  4. Steven a dit (le 22 mars 2005 à 18h39)
    encore une beta : AutoGK (Auto Gordian Knot) 2.00 beta
    • AVI input support
    • Initial support of new DIVX media format
    Télécharger AutoGK (Auto Gordian Knot) 2.00 beta
    Source : FileForum
  5. LeMoi a dit (le 2 octobre 2005 à 21h05)
    L'aventure prend fin
    Originellement posté par len0x
    Those who didn't believe this day would come - were wrong This is officially last version of AutoGK that I'm going to release. Never say never, but at the moment I have no plans of continuing developing it. Reasons are the usual ones: lack of time and motivation. I was struggling with keeping the development up for almost a year and nothing really worked out in the end (but users managed to give me a lot of grief during DAE story). So its over for now. I might still do some updates to include latest version of software used in the package if I'm around, but no changes to the core AutoGK should be expected.
    Change log:
    - updated multilingual tutorials
    - audio/sub selection is remembered during consequential opening of files (again)
    - .credits hidden option can be used for AVI input as well
    Enjoy.
Commenter l'actualité “Auto Gordian Knot 1.53 beta Update”
