NDFR : ATITool v0.0.20
ATITool est un utilitaire permettant d'overclocker une carte vidéo ATI. Il permet aussi de vérifier la stabilité de cette dernière.
Voici les nouveautés :
  • Position of the main window is saved now
  • Rendering in a remote desktop session is now disabled
  • Added info box: "ATITool will not work with TemporalAA enabled"
  • Added "dump bios" function - please report back with which cards this is not working
  • Sliders now default to 0.4x to 1.6x of frequency
  • Hotkey in profile properties shows "none" if no hotkey is set
  • Radeon 9100 IGP is no longer incorrectly detected as supported chip - this fixes a bluescreen/reboot issue, thanks Valar
  • Fixed sys driver problem where bios address would be incorrectly detected - this fixes a bluescreen/reboot issue, thanks Gaston
  • Made the background a bit less red on non-ps 2.0 cards.
  • Added support for R420 overclocking
  • Fixed 'load on windows startup' not working when your installation path had a space in it.
  • Fixed disappearing entry in taskbar when settings are active.
  • Fixed small tooltip typo.
  • Changed code to reduce big frequency jumps (which sometimes results in crashes), max. change is 16 Mhz in 10 ms.
  • Changing AA/AF settings now resets display adapter.
  • Added temperature monitoring for 9600XT, 9800XT, X800
  • Fixed frequencies not switching back when leaving 3D mode. A quick fix for this is in earlier versions is to enable 'play sound when leaving 3d mode'.
  • List clock speeds with profile in combobox
  • Fixed buggy characters in comment of auto-created default profile.
  • Code cleanup
Télécharger ATITool v0.0.20
Source : Warp2Search.Net
1 actualité similaire
  1. Informatique (logiciels) Version française de ATITool !
Afficher l'actualité “ATITool v0.0.20” sur le forum
