Après une nouvelle version de CloneCD, Slysoft publie une nouvelle version de AnyDVD.
Les changements (en anglais) :
- New: Added option to start external programs on disc insertion of non-Video material
- New: Added option to start external programs if material has 60 Hz refresh rate (NTSC)
- New: Added option to start external programs if material has 50 Hz refresh rate (PAL)
- New: Added option to start external programs on disc removal
- The above options are useful to adjust the screen refresh rate to the inserted media contents
- New: Added utility "SetDisplayFrequency" to set and reset the refresh rate of your monitor or beamer
- External tools like MultiRes or PowerStrip can be used as well!
- New: Removed "Information" Menu Item, added "About" Tab in settings window
- New: If a DVD drive is added or removed, the drive selection list will display this change immediately
- Bugfix: After settings were changed, changes did not become effective before a media change
- Bugfix: AnyDVD accidently started a rescan, if non CD/DVD drives/volumes were added or removed (e.g., USB Sticks)
- Bugfix: If a DVD-ROM didn't had a drive letter assigned, the settings dialog could display a "Index out of bounds"
error message!
- Bugfix: If AnyDVD was enabled, DVD-RAM was read only
- Removed ElbyCheck.exe from distribution
- Added Swedish language, updated many other languages
Vous pouvez télécharger AnyDVD 2.1.0.9 sur le site officiel ou chez Seb de Blue-Hardware.
Source : Blue-Hardware
Commenter l'actualité “AnyDVD 2.1.0.9”
